Up to 20% off select tools
Guides
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background and Identification
G&G Armament is a Taiwanese manufacturer of Airsoft products. Airsoft guns are replica toy guns used in airsoft sports. They are a type of low-power smoothbore air guns designed to shoot non-metallic spherical projectiles which are made of various materials like plastic or biodegradable resin materials. Airsoft gun power plants are designed to have low muzzle energy ratings (less than 1.1 foot-pounds) and the pellets have less penetrating and stopping powers than conventional airguns, making them generally safe for competitive sporting and recreational purposes (if proper protective gear is worn).
The G&G Combat Machine 16 Carbine is a full metal and upgradeable airsoft automatic electric gun (AEG) modeled after the M4 Carbine. The M4 Carbine is an air-cooled, gas-operated, magazine-fed carbine that is extensively used by the United States Armed Forces. G&G’s M4 Carbine has moving parts linked directly to the main mechanism of the gun. The G&G Combat Machine 16 Carbine includes a G&G M4 450 round high capacity magazine with an adjustable hop-up and a six-position retractable crane stock. The airsoft gun has a removable rear sight with a weaver rail base for scope mounting and adjustable front and rear sights. This model includes a 14mm negative threaded barrel. It shoots pellets at a muzzle velocity of between 370 and 400 feet per second. This airsoft gun can shoot 20-gram pellets.
The G&G Combat Machine 16 Carbine’s battery compartment is located in the forearm of the rifle and is accessed by pulling down on the delta ring and pulling off the lower half of the handguard.
Technical Specifications
  • FPS Range: 370-400
  • Color: Black
  • Length: 785 / 885mm
  • Weight: 2800g
  • Inner Barrel Length: 363mm
  • Gearbox: Version 2
  • Muzzle Velocity: 370-400FPS
  • Magazine: 450 rounds G&G Hi-cap magazine. (Use all M4 / M16 series Magazine)
  • Package Includes: Gun, Hi-cap Magazine, Cleaning rod, and manual.
  • Motor: Long Type
  • Battery: Butterfly Type (Battery & Charger Not Included.)
  • Fire Mode: Full/Semi-Auto, Safety
  • Manufacturer: G&G - Combat Machine series / Taiwan
Additional Information
G&G Armament Combat Machine CM16 Raider et Carbine — Mode d'emploi
Author
with
Andrew Optimus Goldheart
516,605 Reputation
405 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 71
All Time: 7,149
