Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Potential Student Project
This page has been tagged for revision by students in our education program.
Student In Progress
This wiki is being worked on by hardworking students.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
GE Healthcare LOGIQ™ P6/P6 Pro Service Manual Direction 5245279 Revision 3
Background
GE Healthcare's LOGIQ P6/P6 Pro is a multi-purpose ultrasound system developed by GE Healthcare, designed to support a wide range of diagnostic applications, including general diagnosis, obstetrics, abdominal, gynecologic, vascular, and other medical examinations.
The BT09 was planned for market introduction in 2009, followed by the BT11, which received FDA clearance in October 2010. These two versions represent successive developments in the LOGIQ P6/P6 Pro product line, with BT11 retaining the core functionalities of BT09 while introducing additional features, software, and hardware updates.
LOGIQ P6/P6 Pro is highly portable, allowing healthcare professionals to move it to the patient's bedside or use it in exam rooms with limited space. The device is also equipped with GE Healthcare's proprietary TruScan architecture that provides data processing, real-time 4D imaging capabilities, and system functionality upgrades.
Several key imaging technologies include Speckle Reduction Imaging (SRI), CrossXBeam, DualBeam, B-Flow, Phase Inversion Harmonics, and Coded Technologies. These technologies can enhance image resolution, reduce noise, differentiate tissue structures, and aid in blood flow visualization. In addition, the device further incorporates Raw Data technology to review recorded examination data and adjust image parameters after the initial scan.
Identification
The LOGIQ P6/P6 Pro has a compact and mobile cart design, featuring a 17-inch anti-glare monitor, rear storage shelf, footrest, operating keypad, and control panel.
The main console has ultrasound probe connection ports, a probe holder, a gel tray, a front handle, and lockable wheels.
Users can find the identification and rating plate beneath the monitor, with a printed sticker displaying the scanner's serial number and model details on the lower rear side of the console.
Technical Specifications
General Information
  • Manufacturer: GE Healthcare
  • Product Model: LOGIQ P6/LOGIQ P6 Pro
  • Device Type: Mobile color Doppler ultrasound system
  • System Architecture: GE TruScan
Physical Dimensions
  • Width: 16.93 in
  • Depth: 25.2 in
  • Height: 33.1/ 5.4 in (console configuration)
  • Maximum Height: 60.0/57.7 in
  • Minimum Height: 53.5/51.2 in
  • Weight: Approximately 80kg (176 lb)
  • Wheel Diameter: 4.9 in
  • Mobility: Mobile cart with integrated wheel locking
  • Other Components: Front handle with removable probe holders, gel holder, and air filters
Display
  • Type: TFT LCD
  • Screen Size: 17 in
  • Resolution: XGA, 1024 × 768 pixels
  • Display Adjustment: Tilt, rotate, horizontal/vertical positioning
  • Tilt Range: +40° to −90°
  • Rotation Range: ±90°
  • Horizontal Translation: ±442 mm
  • Vertical Translation: 165 mm
Storage and Connectivity
  • Internal Hard Drive: 250 GB
  • Optical Drive: Integrated DVD-R/W
  • Active Probe Ports: 3
  • External Storage: USB 1.1/2.0 memory devices and external USB 2.0 hard drives
  • Network Connectivity: Ethernet
  • Serial Interface: RS-232 (requires a converter cable)
  • Medical Imaging Connectivity: DICOM 3.0 (optional)
Electrical Specifications
  • Input Voltage: 100–120 VAC or 220–240 VAC
  • Frequency: 50/60 Hz
  • Maximum Power Consumption: 950 VA (with built-in and onboard peripherals)
  • Maximum Thermal Output: 2,500 BTU/hr
Imaging and Scanning
  • Imaging Architecture: Digital beamformer
  • System Processing Channels: 7,168
  • Maximum Frame Rate: Greater than 700 frames per second
  • Frequency Range: 1–15 MHz
  • Maximum Field of View: Up to 170°, depending on the transducer
  • Maximum Displayed Imaging Depth: 30 cm
  • Imaging Technologies: TruScan, CrossXBeam, Speckle Reduction Imaging (SRI-HD), Phase Inversion Harmonics, Coded Harmonic Imaging, Raw Data processing
  • Other Imaging Features: Real-time 3D/4D imaging, B-Flow, Power Doppler Imaging (PDI), Tissue Velocity Imaging (TVI; optional)
Scanning Methods
  • Electronic sector
  • Electronic convex
  • Electronic linear
  • Real-time 4D volume scanning
Compatible Transducer Types
  • Sector phased-array
  • Convex array
  • Microconvex array
  • Linear array
  • Single continuous-wave (CW) pencil probes
  • Bi-plane microconvex array
  • Volume probes (4D)
Operating Modes
  • B-Mode
  • M-Mode
  • Color Flow Mode (CFM)
  • Power Doppler Imaging (PDI)
  • Pulsed-Wave Doppler (PW)
  • Continuous-Wave Doppler (CW; optional)
  • B-Flow (optional)
  • Real-time Triplex Mode
  • 3D/4D imaging modes
Source:
GE Healthcare LOGIQ P6/P6 Pro Service Manual
Product Data Sheet (PDF)
Additional Information
GE Healthcare LOGIQ P6 Pro – Proficient Ultrasound Brochure
LOGIQ P6/P6 Pro BT09 iSERV Note
LOGIQ P6/P6 Pro BT11 iSERV Note
LOGIQ P6 Pro – TruScan Imaging Technology Product Data Sheet
GE LOGIQ P6 Video Demonstration
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 88
All Time: 379
