Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
GE Healthcare LOGIQ 100 PRO Service Manual
Background
The GE Healthcare LOGIQ 100 PRO is a portable ultrasound imaging system used for general diagnostic imaging in a variety of clinical settings. Released in the late 1990s and early 2000s, the LOGIQ 100 PRO was designed as an affordable and reliable option for medical practices that required a lightweight and transportable ultrasound machine. It supports multiple scan applications including abdominal, OB/GYN, vascular, urology, and small-parts imaging, depending on the probe attached.
The LOGIQ 100 PRO features a compact body with an integrated display, control panel, and multiple probe ports. Its portability makes it useful for bedside examination or mobile clinics. The device can output video to external recording systems and supports optional printing accessories. Like other models in GE’s LOGIQ series, this system earned a reputation for durability and consistent imaging performance.
No major manufacturer recalls were reported for this model. The most common issues encountered relate to aging internal components, such as power supply failures, keypad wear, image distortion due to probe damage, or degraded internal connectors. Despite its age, the LOGIQ 100 PRO remains in use internationally due to its reliability, low maintenance requirements, and the availability of replacement parts and service documentation.
Identification
The GE Healthcare LOGIQ 100 PRO has a distinct compact, portable design with a fold-up monitor and a control panel containing physical buttons, dials, and a trackball. The model name “LOGIQ 100 PRO” is typically printed on the front panel near the control interface. The system includes a top-mounted handle for carrying, and depending on the configuration, may have one or more probe ports on the right side or front of the device.
The device’s ports and controls include video output, printer or USB-style output (depending on revision), a power connector, and a potential footswitch input. The model number and serial label are found on a sticker located on the underside or back of the device. This model only comes in a light gray exterior color.
Technical Specifications
System
  • Applications: OB/GYN, abdominal, vascular, urology, small parts
  • Display: Built-in monitor (varies by unit revision)
  • Controls: Physical keypad, dials, and trackball
  • Supported Probes: Convex, linear, micro-convex / transvaginal
Performance
  • Imaging Modes: B-mode and M-mode (depending on probe)
  • Measurement Capabilities: Standard measurements for general ultrasound exams
Connectivity
  • Video Output: For external display or recording
  • Peripheral Support: Printer output (varies), footswitch connector
Power
  • Standard AC input
  • Internal power supply with fuse protection
Serviceability
  • Modular internal design
  • Replaceable display, keypad assembly, PCBs, and probe connectors
  • Built-in system diagnostics
Source:
• GE Healthcare LOGIQ 100 PRO Service Manual
• MedWrench Equipment Database
• User and Service documentation archives
Additional Information
Here are some helpful resources for more details about the LOGIQ 100 PRO:
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 37
All Time: 299
