Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Models
FRT21IL5DB0, FRT21IL5DB2, FRT21IL5DB3, FRT21IL5DB4, FRT21IL5DB6, FRT21IL5DB7, FRT21IL5DB8, FRT21IL5DB9, FRT21IL5DBA, FRT21IL5DBB, FRT21IL5DBE, FRT21IL5DBF, FRT21IL5DBG, FRT21IL5DBH, FRT21IL5DBN, FRT21IL5DBP, FRT21IL5DBR, FRT21IL5DMF, FRT21IL5DMG, FRT21IL5DMH
Show 32 more FRT21IL5DQ0, FRT21IL5DQ1, FRT21IL5DQ2, FRT21IL5DQ3, FRT21IL5DQ4, FRT21IL5DQ5, FRT21IL5DQ6, FRT21IL5DQ7, FRT21IL5DQ8, FRT21IL5DQ9, FRT21IL5DQA, FRT21IL5DQN, FRT21IL5DQP, FRT21IL5DQR, FRT21IL5DW0, FRT21IL5DW2, FRT21IL5DW3, FRT21IL5DW4, FRT21IL5DW6, FRT21IL5DW7, FRT21IL5DW8, FRT21IL5DW9, FRT21IL5DWA, FRT21IL5DWB, FRT21IL5DWC, FRT21IL5DWE, FRT21IL5DWF, FRT21IL5DWG, FRT21IL5DWH, FRT21IL5DWN, FRT21IL5DWP, FRT21IL5DWR
Background
The Frigidaire FRT21IL5D is a top freezer refrigerator without an ice-through door, produced by Electrolux Home Products. The device uses R-410A refrigerant and features an anti-sweat heater switch. The refrigerator measures 68 inches in height, 30 inches in width, and 34 inches in depth.
The refrigerator has a total storage volume of 20.6 cu. ft., with 15.4 cu. ft. allocated for fresh food and 5.3 cu. ft. for the freezer. The unit has an automatic defrost type and an annual energy use of 509.2 kWh/year, slightly below the US Federal Standard of 511.0 kWh/year. It was added to the market in 2005.
Technical Specifications
  • Manufacturer: Electrolux Home Products - Minnesota
  • Brand Name: Frigidaire
  • Model Number: FRT21IL5D*
  • Refrigerator Style: Top Freezer w/o Ice thru-door
  • Defrost Type: Automatic
  • Type: Refrigerator
  • Refrigerator Access: Door
  • Anti-Sweat Heater Switch: Yes
  • Refrigerant Type: R-410A (Non-Ozone Depleting)
  • Insulation Type: Ozone-Depleting
  • Fresh Food Volume (cu ft): 15.4
  • Freezer Volume (cu ft): 5.3
  • Total Volume (cu ft): 20.6
  • Height (inches): 68
  • Width (inches): 30
  • Depth (inches): 34
  • Annual Energy Use (kWh/year): 509.2
  • US Federal Standard (kWh/year): 511.0
  • Date Added: 2005
  • Source: California Energy Commission
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 415
