Ask a Question
There are no questions. Be the first to ask a question!
Models
FRS26LH5DB0, FRS26LH5DB2, FRS26LH5DB4, FRS26LH5DB5, FRS26LH5DB7, FRS26LH5DQ0, FRS26LH5DQ1, FRS26LH5DQ2, FRS26LH5DQ4, FRS26LH5DQ5, FRS26LH5DQ7, FRS26LH5DS0, FRS26LH5DS1, FRS26LH5DS2, FRS26LH5DS3, FRS26LH5DS4, FRS26LH5DS5, FRS26LH5DS6, FRS26LH5DS9, FRS26LH5DSA
Show 11 more FRS26LH5DSB, FRS26LH5DSC, FRS26LH5DSP, FRS26LH5DSR, FRS26LH5DW0, FRS26LH5DW1, FRS26LH5DW2, FRS26LH5DW3, FRS26LH5DW4, FRS26LH5DW5, FRS26LH5DW7
Background
The Frigidaire FRS26LH5D* is a side-by-side refrigerator with an ice dispenser integrated into the door. Manufactured by Electrolux Home Products, it was introduced in 2004. The refrigerator has a total volume of 26.0 cu ft, with 16.5 cu ft allocated for fresh food storage and 9.5 cu ft dedicated to the freezer. It measures 68 inches in height, 36 inches in width, and 34 inches in depth.
The Frigidaire FRS26LH5D* uses R-410A refrigerant, which does not deplete the ozone layer. It also features an anti-sweat heater switch. The refrigerator's annual energy usage is 618.0 kWh/year, which is under the US Federal Standard of 730.0 kWh/year. The refrigerator can be accessed through the door, and it has an automatic defrost function.
Technical Specifications
  • Manufacturer: Electrolux Home Products - Minnesota
  • Brand Name: Frigidaire
  • Model Number: FRS26LH5D*
  • Refrigerator Style: Side-by-Side w/Ice thru-door
  • Defrost Type: Automatic
  • Type: Refrigerator
  • Refrigerator Access: Door
  • Anti-Sweat Heater Switch: Yes
  • Refrigerant Type: R-410A (Non-Ozone Depleting)
  • Insulation Type: Ozone-Depleting
  • Fresh Food Volume (cu ft): 16.5
  • Freezer Volume (cu ft): 9.5
  • Total Volume (cu ft): 26.0
  • Height (inches): 68
  • Width (inches): 36
  • Depth (inches): 34
  • Annual Energy Use (kWh/year): 618.0
  • US Federal Standard (kWh/year): 730.0
  • Date Added: 2004
  • Source: California Energy Commission
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,885 Guides authored
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 27
All Time: 361
