Up to 20% off select tools
Student In Progress
This wiki is being worked on by hardworking students.
Potential Student Project
This page has been tagged for revision by students in our education program.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Frigidaire FDB679 is a built-in dishwasher released around 1998 as part of Frigidaire's 600 and 900 series. It fits standard 24-inch kitchen cabinets and was built to handle everyday family dish loads with a few basic wash cycles.
Major features and Components
  • Wash & Rinse System: Utilizes lower and upper spray arms powered by a central circulation pump to distribute water across durable dish racks.
  • Heating Element: Positioned at the base of the tub to heat water during wash cycles and facilitate thermal air-drying.
  • Electromechanical Timer/Control Unit: Manages cycle progression, water fills, and heating phases.
  • Drain & Inlet Assemblies: Features an inlet water valve to regulate water intake and a dedicated drain pump to expel gray water through the household plumbing.
  • Door Assembly & Latch: Houses the door gasket seal and latch safety mechanism to prevent leaks and ensure the unit only operates when securely closed.
Known Failure Modes and Common Issues
  • Drainage Failures: Over time, food debris can clog the sump or drain hose, preventing the pump from clearing water properly.
  • Water Leaks: Worn door gaskets, cracked tub seals, or aging water inlet valve connections can cause leaks underneath or in front of the unit.
  • Heating and Drying Issues: A failed heating element or tripped thermal fuse will leave dishes wet and cold at the end of a cycle.
  • Latch and Switch Wear: Plastic door latches and microswitches can become brittle or misaligned, preventing the dishwasher from starting.
Because this is an older model, parts like door latches, water valves, heating elements, and drain pumps can wear out over time. This page provides clear guide information to help homeowners, renters, and technicians fix their dishwashers themselves while saving money, and keeping working appliances out of scrapyards.
Identification
To confirm that you are working on the Frigidaire FDB679 series dishwasher, look for the following physical characteristics and model markers:
  • Model Number Location: Open the dishwasher door and look along the top or side metal perimeter of the tub/door frame for the manufacturer data sticker. The exact model number (FDB679) will be printed here along with the serial number and electrical ratings.
  • Control Panel Layout: Features a front-facing push-button control console with cycle status indicator lights across the upper portion of the door.
  • Exterior Finish: Commonly found in standard kitchen finishes such as white, black, almond, or stainless steel panels.
Technical Specifications
  • Appliance Type: Built-in Standard Dishwasher
  • Series / Model Line: FDB679 (600 / 900 Series)
  • Release Era: Circa 1998
  • Standard Width: 24 inches
  • Electrical Requirements: 120V, 60 Hz, 15 Amp dedicated circuit
  • Water Supply Connection: 3/8" or 1/4" NPT water supply line
  • Primary Materials: Steel tub frame, plastic interior components, nylon-coated racks
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 111
All Time: 413
