Up to 20% off select tools
Guides
Documents
Models
This category covers Fiat 500 Hybrid (2020, 2021, 2022, 2023, 2024, 2025, 2026) models.
Motorisation (1.0 FireFly N3 BSG)
The Fiat 500 Hybrid is available with a single light hybrid inline three-cylinder engine mounted to the front of the vehicle. The engine itself is fed by a multipoint indirect injection with distribution ensured through the chain.
Technical Specifications
ElementUnit1.0 FireFly N3 BSG
Cylinder Capacitycm³999
Boremm70.0
Strokemm86.5
Bore / Courseφ0.809
Compression Ratioφ12
Fuel RecommendedN/A95 RON, E10
Euro StandardsN/A6
PowerkW51
Max Speedrpm6,000
TorqueNm92
Maximum boost pressureBarN/A
Manual Transmission Gear
Distribution
Distribution is provided through a silent chain, although this is variable and has the particularity to drive the water pump.
Parallelism
  • Front Wheels ***
Running Values:
Toe-in between rims (mm)0.5 ± 1 mm
Rear wheels
At first glance
Motor Oil
Viscosity0W20
Manufacturer Standard9.55535-DM1
ACEA StandardACEA C5
Genuine oilSelenia ECO2
Volume2.2 L (2.5 L with filter)
Note:
ACEA C6 is compatible with ACEA C5. It's worth opting for the latter, as more tests are required, including a timing chain elongation test. The Fiat standard requested is currently hard to find.
Manual gearbox oil
Viscosity75W
Manufacturer's standard9.55550-MZ6
API StandardGL4+
Original OilTutela Transmission Gearforce
Brake fluid + clutch
StandardsF.M.V.S.S. n° 116, DOT 4, ISO 4925, SAE J1704
Manufacturer's standard9.55597 or MS.90039
Original fluidTutela Top 4/S
Ethanol / E85
At first glance, the engine seems to be a good candidate for easy conversion to ethanol, thanks to its indirect injection and rather high compression ratio (12:1).
The N3 engine, not BSG, but identical in specification to the N3 BSG, is used in Brazil as a Flex Fuel engine. It produces a few more horsepower and more torque at a slightly lower rpm.
Sources and more information
https://www.autopareri.com/forums/topic/...
https://en.wikipedia.org/wiki/Fiat_Globa...
Special thanks to these translators:
fr en
100%
+1
and 1 other...
These translators are helping us fix the world! Want to contribute?
Start translating ›
Past 24 Hours: 9
Past 7 Days: 67
Past 30 Days: 264
All Time: 24,250
