Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Background
Evinrude outboard motors are legacy marine propulsion engines associated with Outboard Marine Corporation and BRP. BRP discontinued Evinrude E-TEC and E-TEC G2 outboard production in 2020, but many Evinrude outboards remain in service.
Identification
Identify a Evinrude outboard motor by the brand name on the engine cowling and the model or serial number plate on the transom bracket, swivel bracket, or clamp bracket.
Evinrude outboards are typically identified by the Evinrude name on the cowling and a model or serial number on the transom bracket or engine label. The exact model code is important because older two-stroke, FICHT, E-TEC, and E-TEC G2 engines use different parts and diagnostic procedures.
Common Service Areas
  • Spark plugs, ignition, coils, and stator checks
  • Carburetor cleaning, fuel pump service, and fuel-line replacement
  • Cooling water pump impeller and thermostat service
  • Gearcase oil, propeller, seals, and lower-unit service
  • Control cable, shift linkage, and throttle linkage adjustment
  • Model and serial number lookup before ordering parts
Additional Information
Author
with
Tim Asp
46,057 Reputation
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 68
All Time: 301
