Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
This troubleshooting page will aid in the diagnosis of any problems pertaining to the Epson Home Cinema 2150
Background
The Epson Home Cinema 2150 was first introduced back in 2017 as a home entertainment projector for family use. Epson Home Cinema 2150 was made to emit bright light and colorful images for display, this device does not display the DLP rainbows that most projectors do, projecting images clearly for the viewers. The Epson Home Cinema 2150 has a wide zoom range, which allows it to be placed at a considerable distance from the desired canvas, up to 11 feet or more. The Epson Home Cinema 2150 can withstand and project the 1080p/60 image or footage and play 3D movies. This projector is wireless allowing it to connect with any device capable of blue-tooth and project sound through the set of speakers included. The lifetime of this projector’s lamp is approximately 4500 hours in normal mode and up to 7500 in its specialized Eco mode.
Identification
The Epson Home Cinema 2150 is a bright high resolution projection system. It supports wireless connectivity, a wireless remote control, HDMI connection cable, mac and windows software. Its Lens is located in the front, the lamp cover is located at the back top left side of the projector, air-filter intake vent and cover is located on the right side of the projector and directly opposite to that is the exhaust vent. At the back of the vent  we can locate all the connection types included such as: AC Input, Speaker, Remote control receiver, HDMI port 1 and 2, PC port and USB Type A port. Finally the control panel which can be located at the top and includes: the wireless LAN, status light, power button, home button, menu button, enter button, escape (esc)  button, source button and the volume. Finally the model number is located at the bottom of the device.
Specifications
Projector
  • Projector Size: 4.80” x 12.20” x 11.20” (HxWxD)
  • Weight: 7.7 lbs
  • Audible Noise: 37dB/ 29 dB (eco)
  • Internal Speakers: 10.00 Watts Mono
  • Power: 312 Watts 100 V - 240 V
  • Connection Panel:
    • Audio Out Mini Jack
    • USB
    • HDMI
    • VGA In: Dsub -15pin
    • HDMI (MHL)
    • Wireless Networking
  • Features:
    • Full HD 3D
    • Frame Interpolation
    • Geometric Correction
    • Miracast
  • Native Resolution: 1080p (1920 x 1080)
  • Color Brightness: 2500 lumens
  • White Brightness: 2500 lumens
  • Aspect Ratio: Native 16:9 widescreen
  • Contrast: up to  60,000:1
  • Display Type: 3LCD, 3 - chip technology
  • Display Performance: 1920 x 1080 native 1080p; HD, 2D, 3D
  • Color Processing: Full 10 bits
  • Size projected distance: 30”-300” at (2.86 ft - 29.2 ft)
  • Throw Ratio Range: 1:33 (Zoom Wide) - 2.16 (Zoom: Tele)
  • Color Modes: Dynamic, Bright Cinema, Natural, Cinema, 3D Dynamic, 3D Cinema
 Lamp
  • Lamp Type: 200 W UHE
  • Lamp Life: 4000 hours of normal life and 7500 with ECO mode
  • Lamp Model: ELPLP96/V13H010L96
 Lens
  • Lens Shift: Manual
  • Focal Length: 18.2-29.2 mm
  • Zoom Ratio: 1.0-1.6x manual
Additional Information
Source: Epson Home Cinema 2150 Wireless Specifications
Projector Central Spec
Epson Home Cinema 2150 Manual
Epson Home Cinema 2150 on Amazon
Epson Home Cinema 2100/2150 Guia de instalação
Epson Home Cinema 2100/2150 Manual del usuario
Epson Home Cinema 2100/2150 User's Guide
Epson Home Cinema 2100/2150 Guía de instalación
Jose Vazquez
224 Reputation
1 Guide authored
CSU Los Angeles, Team 6-2, Adachi Fall 2022 Member of CSU Los Angeles, Team 6-2, Adachi Fall 2022
CSULA-ADACHI-F22S6G2
4 Members
60 Guides authored
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 43
All Time: 2,150
