Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
General
The Elli Charger Standard serves as the base model within the first-generation Elli Charger lineup. It provides a convenient home charging solution for electric vehicles, delivering up to 11 kW of charging power. Equipped with an integrated charging cable, it's compatible with Type 2 connector-equipped EVs. This straightforward option offers a user-friendly way to charge your electric vehicle at home, devoid of the advanced smart features found in the higher-tier Elli Charger models.
Technical Specification
Product Configuration
Charging ModeMode 3 (IEC 61851)
Access Control-
Internet- / Network Communication-
Communication Protocols-
Metering-
Electrical Properties
1 Phase3 Phase
Rated Voltage (± 10 %)1x 230 V400 V (3x 230 V)
Rated Frequency50 Hz
Rated Current1x 32 A3x 16 A
Max. Charging Capacity
(depending on individual configuration)
7,4 kW11 kW
Charging PlugAC – Type 2
Charging Cable Length4,5 m or 7,5 m
Installation Wiring Cross Section1 – 10 mm21 – 6 mm2
Internal Earth Leakage SensorIΔn DC ≥ 6 mA (IEC 61851)
Additionally needed Upstream Protection- Residual Current Detection minimum Type A (30 mA AC)
- Circuit Breaker 32 A (1 Phase) or 16 A (3 Phase)
Physical Properties
Dimensions
[W x H x D] (in mm)
297 x 406 x 116
Status IndicationLED based HMI
Enclosure RatingsIK 10 (IEC 62262)
IP 54 (IEC 60529)
Weight
(depending on variant and charging cable length)
5,6 kg … 7 kg
Operating Temperature-30 °C … +50 °C
Max. Humidity95 % (non-condensing)
Max. Altitude4000 m a.m.s.l.
Mounting MethodOn Wall
Dynamic Load Managementvia AC Current Sensors (optional additional material needed)
Author
with
Sebastian
33,966 Reputation
72 Guides authored
German Translators Member of German Translators
Community
52 Members
6,638 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 29
All Time: 625
