1 Diagram
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Documents
Background and Identification
The Electric Eel Drain Cleaner model KK-1/2IC50 is a drain cleaner built on a steel frame with a hand-crank. The machine includes 50 feet of 1/2-inch cleaning cable that is designed to clean 1-1/4-inch to 3-inch diameter drain lines. The drain cleaner is manual-powered and designed for rooftop work in downspouts because of its light weight. It includes Flexicore wire rope-center cables that are designed to be strong, flexible, and long-lasting.
The KK-1/2IC50 does not include a motor and is powered by hand. A metal handle on the crank turns the drain cleaner’s cage on self-aligning bearings on the front and rear of the frame. It also includes steel side braces on the frame for added durability and stability. The drain cleaner features a powder-coated cable cage that rotates freely and a thumbscrew that locks the cable at the front of the cage.
The KK-1/2IC50 model includes a steel frame with the coil of the cleaning line placed in the center of the frame. The model’s steel frame is painted medium blue. The name “Electric Eel” is printed in white cursive font on the front of the machine’s motor. The unit weighs 43 pounds, including the coil of cable.
Technical Specifications
Details:
- Weight (lbs.): 43 lbs
- Power Type: Manual
Dimensions:
- Assembled Depth (in.): 18 in
- Assembled Height (in.): 20 in
- Assembled Width (in.): 13 in
