1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
SA1
Background and Identification
Eddy is a company that sells floor maintenance equipment, including floor polishers, tile breakers, and strippers. The SA1 is a compact floor stripping machine that removes flooring to make way for a new floor covering or material. This machine is compatible with carpeting, underpadding, vinyl tiles, glue, and other floor coverings. The edge at the front of the machine wedges under the existing flooring, and then the operator pushes the machine along, pulling up the flooring as it moves forward. This floor scraper has three different kinds of blades for different flooring materials. It also has an extendable handle to make it easier to operate. The compact design of this floor stripper is intended to make it easier to use on small, hard to reach spaces such as stairs or small rooms.
This product can be purchased from the manufacturer, but it is also available for rent from a third party, such as Home Depot. The operator of this machine should always be careful to follow all safety instructions given in the operating manual.
Technical Specifications
  • Assembled Depth: 14 in
  • Assembled Height: 6 in
  • Assembled Width: 15 in
  • Dry Weight: 32lbs (14.54Kg)
  • Available in 110 or 220V
  • Amperage: 5 Amps
  • Blade Types: 3
  • Extension handle included
  • Decibels: 60 Db
Additional Information
Product Brochure
List of Eddy Products
Home Depot Rental
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 44
All Time: 2,080
