Up to 20% off select tools
Guides
2 Diagrams
Models
RFK-3/4IC100
Background and Identification
The Electric Eel Drain Cleaner model RFK-3/4IC100 (2014) is an automatic-feed drain cleaner. It includes a set of four clearing tools, a spanner wrench, leather gloves, and a tool bag. It features a 12-inch flexible cable leader to help the cleaning cable negotiate bends and clogs. The RFK-3/4IC100 model also includes a cutting cable for clearing roots.
The RFK-3/4IC100 model features a 0.33-horsepower Baldor capacitor electric motor. The motor runs off of 115 Volts. The cable cage can hold up to 100 feet of 3/4-inch cleaning cable and can be removed when switching cable types. The machine weighs 195 pounds.
The RFK-3/4IC100 model’s frame is constructed of 1-1/4-inch steel tubing and is built like a dolly (two wheels for maneuverability and a flat bottom section for resting on the ground). The cleaner’s frame is painted dark blue, and the name “Electric Eel” is printed in white cursive font on the tool pouch attached to the frame’s front. It also includes a handle that can be removed during transportation and working in smaller spaces. The machine also includes two 10-inch wheels attached to the frame.
Technical Specifications
Identification Specifications:
  • Manufacturer: ELECTRIC EEL
  • Model Number: RFK-3/4IC100
  • UPC: 694585201008
Technical Specifications:
  • Motor: 1/3 Hp Baldor Capacitor Start
  • Voltage: 115 V AC Standard
  • Frame: 1" Steel Tubing
  • Cage Capacity: 100' of 3/4" Tri-Max Cable
  • Line Capacity: 3" to 6" Diameter
  • Dimensions: 30.5" L x 17" W x 37" H
  • Weight: 195 lbs.
Additional Information
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 19
Past 7 Days: 94
Past 30 Days: 540
All Time: 36,705
