12 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
HC-3020
Background and Identification
This gas-powered hedge trimmer is manufactured by Echo, a company that produces power tools for garden maintenance. This tool is made of a double sided blade at the end of a long shaft, powered by a 21.1 cc gasoline engine. The double sided blade means that this trimmer can be swept back and forth along a hedge, cutting no matter which way it is moving. This makes the tool much more efficient than a single sided blade.
This hedge trimmer has a 2-stroke gas engine, which means that it is a smaller and lighter engine that runs at a higher rate than a 4-stroke engine would. This makes it ideal for handheld tools such as hedge trimmers because the lighter weight makes it easier for the user to hold for a long period of time. However, two-stroke engines generally have higher emissions than four-stroke engines.  The Chainsaw Journal has more information about the difference between 2-stroke and 4-stroke engines.
This hedge trimmer can be identified by the model number HC-3020. This number can be found on the top of the red engine casing, above the black circle with the Echo logo.
Technical Specifications
  • Blade Length (in): 30
  • Cutter Type: Double-Sided, Double-Reciprocating
  • Dry Weight (lbs): 11.9
  • Engine Displacement (cc): 21.2
  • Carburetor: Rotary
  • Fuel Capacity (fl. oz.): 12.5
  • Starting System: i-30
  • See-Through Fuel Tank: Standard
Additional Information
HC-3020 Product Page
Hedge Trimmer - Wikipedia
Hedge Trimmer Safety Manual
2015 ECHO Hedge Trimmers Catalog
ECHO Hedge Trimmers
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 41
All Time: 2,337
