Up to 20% off select tools
Guides
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
With the Contour Center, Dynaudio have paid particular attention to the woofers, which feature die cast baskets and long throw progressive spiders for the fine control of the membrane.
They have also incorporated aluminium voice coils and five duct coil cooling system to ensure first rate audio performance. All Contour Center drivers use vented magnet systems and each speaker is equipped with magnetically optimized triple shielding which eliminates the risk of interference to televisions and other electrical appliances.
As a final touch, Dynaudio have used environmental friendly damped materials throughout and encased the Contour Center in a stunning wood veneer cabinet that will enhance any listening environment.
Technical Specifications:
Sensitivity (2.83 V/1 m): 86 dB
IEC Long Term Power Handling: 150 W
Nominal Impedance: 6 Ohms
Frequency Response: 80 Hz - 21 kHz
Weight: 11,1 kg
Dimensions (W x H x D): 570 x 165 x 320 mm
Contour Center Official Specifications PDF
Author
with
Matthias Huisken
684 Reputation
1 Guide authored
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 76
All Time: 2,904
