2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Models
F514
Background and Identification
DriEaz sells a variety of dehumidifiers and other anti-water damage products, including the F514. This device is a carpet blower meant to remove moisture from a carpet after flooding or leaks. Quickly removing moisture from a carpet can help prevent water damage, mold, and other harm to the carpet. The F514 carpet blower has three positions that place the vent towards a floor, wall or ceiling, so that this device can dry out any surface. It also features a carpet clamp, which can hold carpet up off the floor so that the F514 can dry underneath the carpet.
DriEaz products can be identified by the blue casing. The F514 also has a unique whistle or snail-shaped case. It may also have an identifying sticker with the model number on it somewhere on the product.
Technical Specifications
  • Model: Carpet Dryer (F514)
  • Weight: 24 lbs. (10.9 kg)
  • Dimensions (D × W × H): 18.5 × 16.5 × 18.5 in. (47.0 × 41.9 × 47.0 cm)
  • Amps: 3.0 A (low) ; 3.5 A (medium) ; 5.0 A (high)
  • Motor Size: ½ HP
  • Power: 115V / 60Hz
  • Sound level: 68 dB (avg.)
  • Controls: Three speed rotary switch
  • Cord length: 15 ft. (4.6 m)
  • Construction: Injection molded housing, wire grill. Stackable.
  • Safety: ETL listed to UL 507 and CSA 22.2 no. 113
Additional Information
Home Depot Rental Page
Operating Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 56
All Time: 7,284
