Up to 20% off select tools
Medical Equipment
Neither iFixit nor this repair information is endorsed by or affiliated with the medical device manufacturer.
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Background
The Drager company started in Germany in 1989, making breathing and gas detection products. Since then, they have upped their range of products and services to anesthesia machines, surgical equipment, ventilators, medical education, vitals monitoring, and other standard medical supplies. Some of the most impressive equipment that Drager makes is that of the anesthesia machines, which are used to carefully deliver oxygen (O2) and nitrous oxide (N2O) to sedate patients. This sedation is to keep patients from feeling pain and accidentally moving during an operation.
The Drager Narkomed M Mobile is a highly mobile version of an anesthesia system often used in the military or smaller medical rooms. The Narkomed M Mobile offers an easy to assemble design with break-resistant flow meters, ventilator integration, and an anesthesia system. Unlike most common anesthesia machines, the Narkomed M Mobile is a fully modular design that makes it easy to spot due to its small size and few parts. However, because the system has been around for quite some time, it has undergone many iterations/updates. Therefore, your model might differ slightly depending on which Rev you have.
Identifying Your Device
The Narkomed M Mobile can be identified by looking at the top of the device where it will say “NARKOMED Mobile”:
Secondary Identifier
You can also identify the device by looking at the back where product information and warning labels are present to see the name “NARKOMED M” located in the top left above the power specifications, as well as the Drager company name to the right of that:
Features
  • Modular design with decreased components to decrease assembly/disassembly time.
  • The small footprint of 2.5 sq. ft.
  • Multiple types of anesthesia techniques:
    • Closed
    • Semi-closed
    • Opened
  • Break-resistant flow meters.
  • Integrated ventilator with a flow rate of 0 - 5 LPM
  • A spill-proof vaporizer with a minimum capacity of 100 ML
  • The operational range of 40-61 PSI
  • Works with both active and passive gas scavenging systems
  • Monitoring capabilities for breathing
Technical Specifications
  • Dimensions
    • Width: 23.6” (59.9 cm)
    • Length: 24.4” (62.9 cm)
    • Height: 53” (134.6 cm)
  • Weight: 75 lbs.
  • Power: 110/220V, 50/60Hz, 250 watts, 2.5 amps max
  • A backup battery that will power the machine at full capacity for at least 1 hour (brand new battery installed)
Additional Information
Drager - Company Site
Seattle Technology - 3rd Party Product Page
Avante Health Solution - 3rd Party Product Page
Soma Medical - Replacement Parts
Part Target - Replacement Parts
First Medical - Additional Pictures
Drager Narkomed M Mobile Video Display
Narkomed Mobile Anesthesia System Operator's Instruction Manual
Narkomed Mobile Anesthesia System Technical Service Manual
Operator & Maintenance Literature for Medical Equipment Disc 6
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 892
