Up to 20% off select tools
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Dodge Stealth Technical Specs (R/T Turbo)
Engine and Performance
  • 3.0L 24V Twin-Turbo V6 (6G72): Features dual overhead cams, intercooled twin turbochargers, and a multi-point electronic fuel injection system.
  • Output: Originally 300 hp (1991-1993), it was bumped to 320 hp and 315 lb-ft of torque (1994-1996) with the introduction of the Series 2 models.
  • Performance: Capable of a 0-60 mph sprint in approximately 5.2 seconds, with a top speed electronically limited to 155 mph.
  • Active Exhaust: A vacuum-actuated valve in the muffler allowed the driver to switch between "Sport" and "Tour" modes, physically altering the exhaust backpressure and acoustic note.
Drivetrain and Transmission
  • Transmission: Early Turbo models featured a 5-speed Getrag manual, while 1994-}1996 models were upgraded to a 6-speed Getrag (V5M42) manual for better gear spacing.
  • All-Wheel Drive (AWD): Utilizes a center viscous coupling differential that splits torque 45:55 (front/rear) under normal conditions, shifting power dynamically based on wheel slip.
  • Four-Wheel Steering (4WS): A hydraulic system that turns the rear wheels in phase with the front wheels at speeds above 30 mph, improving high-speed lane-change stability.
Chassis and Design
  • Electronic Controlled Suspension (ECS): Uses a dedicated computer to monitor speed, G-forces, and steering angle, adjusting the damping rates of the struts in real-time between Soft, Medium, and Hard.
  • Braking: Features massive 4-piston fixed front calipers and ventilated discs at all four corners, supported by a 4-channel ABS system.
  • Aerodynamics: While it lacked the Mitsubishi's "Active Aero" motorized spoilers, the Stealth's body was tuned for a lower drag coefficient (C_d of approximately 0.33) with a signature "wrap-around" rear glass.
  • Wheelbase: 97.2 inches (2,469 mm).
  • Length: 180.5 inches (4,585 mm).
  • Curb Weight: Approximately 3,800 lbs (1,724 kg) for the R/T Turbo.
Author
with
oldturkey03
867,026 Reputation
123 Guides authored
Global Fixers Member of Global Fixers
Community
74 Members
3,048 Guides authored
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 49
All Time: 217
