Up to 20% off select tools
No Image
This wiki is missing a device image. Help improve this page by uploading one!
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
DXPW60606
Background And Identification
The Dewalt DXPW60606 is a pressure washer designed for various cleaning tasks. This powerful device comes with a HONDA 389 cc OHV engine and has a maximum PSI of 4200 and a maximum GPM of 4.0. The pressure washer is equipped with several features, including a panel assembly, nozzle grommets, professional spray gun, wheel, quick-connect spray wand, frame, engine dipstick/oil plug, engine switch, starter grip, engine, throttle control lever, choke control, fuel valve lever, gas cap, handle assembly, high-pressure hose, and high-pressure pump.
Technical Specifications
  • Model: DXPW60606
  • Weight: 145 lbs
  • Height: 25.5 inches
  • Width: 28 inches
  • Length: 45 inches
  • Max PSI: 4200
  • Max GPM: 4.0
  • Engine: HONDA 389 cc OHV
Troubleshooting
If the nozzle becomes clogged with foreign materials, such as dirt, excessive pressure may develop. If the nozzle becomes partially clogged or restricted, the pump pressure will pulsate. Clean the nozzle immediately using the nozzle kit supplied. If the unit is left in bypass mode for more than two minutes, internal components of the pump can be damaged.
More Information
For best results, pump oil designed specifically for pressure washers is recommended, as these contain a rust inhibitor and an anti-foaming agent. If this oil is not available, an SAE 30W non-detergent oil may be used. The high-pressure pump was filled with oil at the factory. Always check the oil level before using. To maintain the pressure washer, change the pump oil after the first 50 hours of operation and every 300 hours thereafter. The water inlet filter screen should be checked periodically and cleaned if necessary.
Dewalt DXPW60606 Instruction Manual
Author
with
eCuration
478,744 Reputation
396 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 378
