Guides
1 Diagram
Documents
Background
Released in 2018, the DeWalt DCN21PL is part of DeWalt's 20V MAX cordless tool platform. The nailer was developed to improve portability and job-site efficiency by eliminating compressors and hoses. Because it runs on a 20V MAX lithium-ion battery, users can work more freely without being tethered to an air source.
Compared with earlier models, the DCN21PL introduced:
  • Improved battery efficiency
  • Reduced tool weight
  • Sequential and bump-fire modes
  • Tool-free jam release
  • Adjustable depth control
The nailer operates under repeated high-impact loads. Over time, internal components such as return springs, the driver mechanism, solenoid assembly, and magazine feed system may wear. Common performance issues include nail jams, weak nail driving force, nails not sinking fully into dense materials, delayed firing, or intermittent operation. Regular cleaning, inspection of moving parts, and timely component replacement can help maintain performance.
As of 2026, there are no widely published manufacturer recalls specific to the DCN21PL in DeWalt’s safety notice listings. Users are encouraged to check official recall resources regularly and perform routine maintenance to support long-term reliability.
Identification
The model number DCN21PL can be found:
  • On the manufacturer's label
  • Near the battery housing
  • On the tool body
Visual identifiers include:
  • Yellow and black DeWalt color scheme
  • 20V MAX battery interface
  • Plastic-collated nail magazine
Correct identification ensures compatibility when replacing parts or following repair guides.
Technical Specifications
  • Power: 20V MAX battery
  • Nails: Plastic-collated framing nails
  • Nail Length Range: 2.0” – 3.25”
  • Magazine holds up to 49 nails
  • Weight: About 8 lbs without the battery
  • Firing Modes: Sequential or bump fire
  • Released: 2018
Common Issues & Symptoms
Users frequently report:
  • Nailer jammed or misfeeding nails
  • Tool not firing
  • Weak nail driving force
  • Nails not sinking fully
  • Delayed firing response
  • Battery performance concerns
  • Return spring or solenoid failures
These issues may require cleaning, adjustment, component inspection, or part replacement.
Additional Information
The DCN21PL is similar to other DeWalt cordless framing nailers, including the DCN692. Certain troubleshooting procedures and maintenance practices may be comparable across models.
For official documentation and support, visit:
Community-based troubleshooting discussions and repair examples can also be found through:
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 156
All Time: 4,898
