Fix a Stuck Pump on a Curtis TLP Commercial Office Coffee Machine
Popular Forum Questions
Ask a QuestionThere are no questions. Be the first to ask a question!
Tools
Pulse Brew Technology: Three pulse brew options allow you to match your fresh ground coffee to the right brew recipe.
Program the Temp: Factory set at 200 degrees with the ability to switch from 190 up to 206 degrees.
Sprayhead Evenly saturates the coffee grounds to extract the richest, fullest flavor from every type of coffee.
Clearance Brews into an airpot with clearance of 11.5 inches.
Halvsies Able to brew a half pot as well, 42 oz/1.25 liters.
Hot Water Convenient hot water spigot on the side.
Height (in.)17.760"Width (in.)10.650"Depth (in.)18.390"
ELECTRICAL
Phase1Volts120Amps12.5Heat Configuration1 x 1450WWire2W+GWatts1500Hertz50/60
WATER
Connector1/4" FlarePressure20 - 90 psiMin. Flow Rate1.0 GPMTank Volume1.6 Gal.
