4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38895
Background
The Craftsman Walk Behind Mower 917.388950 is a gas-powered push lawn mower. Its cutting width is 21 inches and it comes with an adjustable height ranging from 1-3 inches, adaptable across 9 positions. This mower includes mulching and rear bagging capabilities.
The mower is equipped with a 6.5 horsepower Briggs & Stratton model 123K02-0541-E1 engine. It uses regular unleaded gasoline and SAE 30 oil. The 21-inch steel cutting deck is designed for mulching and rear bagging. The mower uses a steel blade and comes with a rear deflector. The mower also features an operator presence control bar which must be held down to start and operate the mower, an adjustable handle height, and a priming button for starting a cold engine. It can transition between mulching and bagging through the use of a mulcher door. A rear grass catcher bag is included as well.
Technical Specifications
  • Model Number: 917.388950
  • Product Type: Walk Behind Mower
  • Engine: 6.5 horsepower Briggs & Stratton model 123K02-0541-E1
  • Cutting width: 21 inches
  • Cutting height: 1-3 inches adjustable via 9 positions
  • Capabilities: Mulching and rear bagging
  • Handle: Adjustable height
  • Starting system: Priming button for cold engine
  • Conversion: Mulcher door allows conversion between mulching and bagging
  • Grass catcher: Rear grass catcher bag included
  • Engine specifications: 123cc Briggs & Stratton 4-stroke OHV gas engine, electric starter and recoil pull start backup, uses regular unleaded gasoline and SAE 30 oil
  • Cutting system: 21 inch steel cutting deck, single lever for adjusting cutting height, uses a 21 inch steel blade, spring-loaded rear deflector included
  • Safety features: Operator presence control bar for starting and operating mower, mulcher door, rear deflector, metal grass catcher to prevent debris discharge
Warranty
The Craftsman Walk Behind Mower 917.388950 comes with a 2-year full warranty from the date of purchase. This warranty is designed to cover any defects in the materials and workmanship of the product. However, do note that items that are subject to normal wear are not included in the warranty coverage. To claim the warranty, it is implied the customer should contact the product manufacturer, Sears, though the specific process or requirements for claims are not detailed in the provided text.
Craftsman 917.388950 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 22
All Time: 531
