1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388932
Background
The Craftsman Walk Behind Mower 917.388932 is a gas-powered lawn mower constructed by Roper Corp for Sears. The mower is equipped with a 6.0 horsepower Briggs & Stratton engine, model 122K02-0577-E1, which uses regular unleaded gasoline with a minimum 87 octane rating. The engine's speed is preset and is not adjustable by the user. The lawn mower features a steel cutting deck with a width of 21 inches and a two-blade side discharge design. The cutting height can be altered from 1-3/4 inches to 4 inches across seven different positions, thanks to a single lever for each wheel.
The Craftsman 917.388932 operates as a push rear wheel drive mower, employing a variable speed system that adjusts its speed based on the pace of the operator. An optional rear grass collection bag can be attached to the mower to collect grass clippings during mowing. Regular maintenance for this lawn mower includes changing the engine oil, cleaning the air filter, replacing the spark plug annually, and sharpening or replacing the blades when necessary. The mower is suitable for most residential yard maintenance needs due to its adjustable cutting height and variable speed drive.
Technical Specifications
  • Model Number: 917.388932
  • Product Type: Gas-powered rotary lawn mower
  • Engine: 6.0 horsepower Briggs & Stratton, model 122K02-0577-E1
  • Cutting Width: 21 inches
  • Drive System: Push rear wheel drive
  • Cutting Height: Adjustable from 1-3/4" to 4" in 7 positions
  • Grass Collection: Optional rear grass catcher available
  • Engine Oil Capacity: 20 oz
  • Fuel Type: Regular unleaded gasoline, minimum 87 octane
  • Cutting Deck Material: Steel
  • Blade Design: 2 blade side discharge
  • Speed Control: Variable speed system, adjusts to operator's walking pace
  • Safety System: Operator presence control bar
Warranty
The Craftsman Walk Behind Mower 917.388932 comes with a warranty period of 2 years. This full warranty covers any defects in materials and workmanship of the mower under normal use. It should be noted, however, that if the mower is used commercially, the warranty period is reduced to 90 days. To claim the warranty, it is typically required to provide proof of purchase such as a receipt, and the defective product or part. The exact process can differ so it's recommended to refer to the specific warranty terms and conditions provided by the manufacturer or seller, or contact them directly for guidance on the warranty claim process.
Craftsman 917.388932 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 31
All Time: 379
