Up to 20% off select tools
3 Diagrams
Documents
Models
917.388853
Background
The Craftsman Walk Behind Mower 917.388853 is a lawn mower with a rear discharge function. This equipment, assembled by Sears, is designed with a 21-inch cutting deck made from steel and features a Briggs & Stratton 4-cycle engine that possesses 6.5 horsepower. The engine, model 123K02-0444-E1, is equipped with an overhead valve design and a recoil starter. For ease of use during cold starts, a primer bulb is incorporated.
The lawn mower's fuel tank has a capacity of 0.95 gallons and it uses standard 87+ octane unleaded gasoline. The cutting deck, on the other hand, has a rear discharge functionality that allows for the mulching or bagging of grass clippings. It also has 9 position height adjustments, ranging from 1-3/4" to 4". Furthermore, the drive system of this lawn mower is a manual push propulsion. The mower measures 43" x 21" x 40" (L x W x H) and weighs approximately 75 lbs. It has a grass catcher for bagging clippings and a side discharge chute for mulching. This mower is suggested for yards up to 1/2 acre in size.
Technical Specifications
  • Model Number: 917.388853
  • Type: Walk Behind Mower
  • Engine: 6.5 horsepower Briggs & Stratton 4-cycle engine, model 123K02-0444-E1
  • Engine Features: Overhead valve design, Recoil starter, Primer bulb for easy cold starts
  • Fuel Tank Capacity: 0.95 gallon, uses standard 87+ octane unleaded gasoline
  • Cutting Deck: 21" steel cutting deck
  • Grass Discharge: Rear discharge for mulching or bagging grass clippings
  • Height Adjustment: 9 position height adjustment from 1-3/4" to 4"
  • Drive System: Manual push propulsion
  • Dimensions: 43" x 21" x 40" (L x W x H)
  • Weight: 75 lbs approximate weight
  • Additional Features: Includes a grass catcher for bagging clippings and a side discharge chute for mulching. Recommended for yards up to 1/2 acre in size.
Warranty
The Craftsman Walk Behind Mower 917.388853 comes with a 2-year limited warranty starting from the date of purchase. This warranty covers any defects in materials and workmanship, provided that the product has been properly maintained. However, it does not cover normal wear parts or any damage resulting from improper use. To claim the warranty, the product details and maintenance records should be presented to the Sears Parts and Repair Centers or through the Briggs & Stratton dealer network.
Craftsman 917.388853 Owners Manual
Author
with
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 632
