No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38873
Background
The Craftsman Walk Behind Mower 917.388730 is a garden maintenance tool manufactured by Roper Corp for Sears. It is designed to cut grass with a 21-inch width blade, powered by a Briggs & Stratton 12H802-2675-B1 4-cycle engine with a displacement of 163cc. The fuel capacity of this mower is 1.6 gallons of unleaded regular gasoline (87 octane minimum). The oil capacity is 20 oz of SAE 30 oil (above 32°F), or SAE 5W-30 oil (below 32°F). The cutting height can be adjusted between 1-3.75 inches, across 9 positions. The mower weighs 60 lbs.
The mower has a 3-in-1 mowing feature which includes mulching, bagging, and side discharge. The machine's engine delivers 6.0 ft-lbs torque. There is an operator presence control bar for enhanced control. The handle of this mower can be folded for compact storage. The mower has a 9-position height adjustment feature and dual ball bearing wheels. It also comes with mulching and bagging blades.
Technical Specifications
  • Model Number: 917.388730
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 12H802-2675-B1 4-cycle engine
  • Displacement: 163cc
  • Fuel Capacity: 1.6 gallons unleaded regular gasoline (87 octane minimum)
  • Oil Capacity: 20 oz SAE 30 oil (above 32°F), SAE 5W-30 oil (below 32°F)
  • Cutting Width: 21 inches
  • Cutting Height: 1-3.75 inches (9 positions)
  • Weight: 60 lbs
  • Mowing Modes: Mulching, bagging, side discharge
  • Engine Torque: 6.0 ft-lbs
  • Operator Presence Control: Yes
  • Folding Handle: Yes
  • Height Adjustment: 9 positions
  • Wheel Type: Dual ball bearing wheels
  • Included Blades: Mulching and bagging blades
Warranty
The Craftsman Walk Behind Mower 917.388730 comes with a 2-year limited warranty. This warranty covers defects in material or workmanship when the product is used for residential purposes. However, it is important to note that the warranty does not cover normal wear and tear, improper use, or abuse of the product. To claim the warranty, refer to the manufacturer's instructions or contact Sears directly, as they are the manufacturers of this product.
Craftsman 917.388730 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 12
Past 30 Days: 28
All Time: 301
