No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38872
Background
The Craftsman Walk Behind Mower 917.388720, manufactured by Roper Corp for Sears, is a lawn mower designed for personal use. The device operates via a 6.0 horsepower Briggs & Stratton 12H802-2639-B1 4-cycle engine. It has a fuel capacity of 1.6 quarts of unleaded regular gasoline and requires oil type SAE 30 above 32°F, SAE 5W-30 below 32°F with an oil capacity of 20 oz. The blade bolt torque is 35-40 ft-lbs.
The device offers both mulching and rear bagging capabilities. Users can adjust the height of the device in 9 different positions, ranging from 1-1/2" to 4". Starting the engine requires priming 3 times then pulling the starter cord quickly while holding down the operator presence control bar. The mulching door and rear discharge door can be adjusted to select mulching, rear bagging or side discharge modes. Maintenance includes checking the engine oil level before each use, cleaning the underside of the mower deck after each use, inspecting, sharpening and balancing the blade periodically, cleaning the air filter annually, checking all hardware periodically and having the engine serviced at least once per year.
Technical Specifications
  • Model Number: 917.388720
  • Product Type: Walk Behind Mower
  • Engine: 6.0 horsepower 4-cycle engine
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade Bolt Torque: 35-40 ft-lbs
  • Capabilities: Mulching and rear bagging
  • Height Adjustment: 9-position from 1-1/2" to 4"
Warranty
The Craftsman Walk Behind Mower 917.388720 comes equipped with a limited two-year warranty. This warranty covers any defects in materials and workmanship for two years from the date of purchase, given that proper maintenance and care are provided as per the instructions in the owner's manual. However, please note that the warranty will be void if the mower is used for commercial purposes. Also, components such as the engine, belts, blades, and other wear items are not included in the warranty coverage. To claim the warranty, adhere to the guidelines provided in the owner's manual, ensure regular maintenance, and report any defects or issues promptly.
Craftsman 917.388720 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 27
All Time: 408
