No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388631
Background
The Craftsman Walk Behind Mower 917.388631 is a gasoline-powered push lawn mower designed for residential use. Manufactured by Roper Corp for Sears, this mower comes with a 4.5 horsepower Craftsman engine with recoil starter. It has a cutting width of 21 inches and offers an adjustable cutting height between 1-3.5 inches. The mower can be operated manually without self-propulsion and uses a 21 inch steel blade for mowing. The mower is equipped with rear discharge, mulching or bagging capabilities.
In terms of specifications, the engine of the Craftsman Walk Behind Mower 917.388631 has a displacement of 140cc. It has a fuel tank capacity of 1.5 quarts and runs on unleaded gasoline. The oil type recommended for this mower is SAE 30 above 32°F and SAE 5W-30 below 32°F with an oil capacity of 20 ounces. The blade bolt torque is between 35-40 ft-lbs and the blade speed is 2900-3200 rpm. This mower comes with 7 inch front wheels and 8 inch rear wheels, and weighs around 60 lbs.
Technical Specifications
  • Engine: 4.5 horsepower Craftsman 143.044500
  • Displacement: 140cc
  • Fuel Tank Capacity: 1.5 quarts
  • Fuel Type: Unleaded gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Blade Bolt Torque: 35-40 ft-lbs
  • Blade Speed: 2900-3200 rpm
  • Cutting Height: 1-3.5 inches (9 position height adjustment lever)
  • Cutting Width: 21 inches
  • Wheel Size: 7 inch front, 8 inch rear
  • Weight: 60 lbs
  • Drive: Push, no self-propulsion
  • Start Type: Recoil start
  • Grass Discharge: Rear discharge, mulching or bagging capabilities
Warranty
The Craftsman Walk Behind Mower 917.388631 comes with a 2-year limited warranty. However, the document does not specify what is covered under this warranty or the process to claim it. To get detailed information about what's covered under the warranty or how to claim it, it's best to refer to the product manual or contact the manufacturer directly.
Craftsman 917.388631 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 37
All Time: 527
