No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388442
Background
The Craftsman Walk Behind Mower 917.388442 is a lawn mower that is powered by gas. It is fitted with a Briggs & Stratton 126T02-1184-EA engine and has a cutting width of 21 inches. The mower has the ability to adjust its cutting height between 1-3 inches, offering a total of seven different positions. This model can store up to 1.6 quarts of fuel and uses SAE 30 oil when the temperature is above 32°F, and SAE 5W-30 when below. The engine oil capacity is 20 oz. The mower uses a Champion RJ19HX spark plug and requires a blade bolt torque of 35-40 ft-lbs.
The Craftsman Walk Behind Mower 917.388442 also offers several additional features. It has a dual lever, allowing for six different height adjustments. The mower provides three different grass management options: rear bagging, mulching, or side discharging. It also includes a T-shaped handle that can be folded for storage purposes. Lastly, it has an operator presence control bar which stops the mower when the operator is not in control. Regular maintenance is required for optimal performance. This includes routine checks on engine oil, changing engine oil, cleaning the air filter, replacing the spark plug, and managing the mower blade.
Technical Specifications
  • Model Number: 917.388442
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 126T02-1184-EA 126 cc
  • Cutting Width: 21 inches
  • Cutting Height: 1-3 inches (7 positions)
  • Fuel Tank Capacity: 1.6 quarts
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Spark Plug: Champion RJ19HX (gap .030")
  • Blade Bolt Torque: 35-40 ft-lbs
  • Height Adjustment: Dual lever, 6 position
  • Grass Disposal: Rear bagging, mulching or side discharge options
  • Handle: Folding T-shaped for storage
  • Control: Operator presence control bar
Warranty
The Craftsman Walk Behind Mower 917.388442 comes with a 2-year full warranty, covering any defects that may arise from materials or workmanship. However, if the mower is used commercially, this warranty is limited to 90 days from the purchase date. The warranty does not extend to expendable parts such as rotary mower blades, blade adapters, belts, air filters, and spark plugs. Additionally, repairs necessitated by operator abuse or negligence, or use outside of the United States, are not covered under this warranty. To claim the warranty, reach out to the manufacturer with your concerns, providing details about the defect and proof of purchase. Ensure that the product has been used and maintained according to the provided instructions to ensure your claim is valid.
Craftsman 917.388442 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 25
All Time: 261
