No Image
This wiki is missing a device image. Help improve this page by uploading one!
4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388381
Background
The Craftsman 21" Walk Behind Mower Model 917.388381 is a rotary lawn mower fueled by gasoline. This mower is designed and produced by Sears. The mower is equipped with a Briggs & Stratton 6.0 horsepower 4-cycle engine, model number 12H802-2675-E1. Other aspects of the mower include a 21-inch cutting width, a 1-3.75 inch cutting height with nine position adjusters, and a 21-inch steel blade. The mower has a 2.3 bushel rear bag for grass clippings and is capable of mulching and side discharge. The mower is fitted with 7-inch front wheels and 8-inch rear wheels and weighs 60 lbs.
The mower's engine has a displacement of 190cc. It runs on regular unleaded gasoline and has a fuel capacity of 1.6 quarts with an engine oil capacity of 20 oz. The engine includes a recoil starter, solid state ignition, and primer carburetor for cold starts. The engine speed is preset by the factory and is not adjustable by the user. The mower's 21-inch steel blade can mulch, bag, or side discharge grass clippings. The cutting height can be adjusted from 1-3.75 inches in nine different height positions using a lever on each wheel. The mower deck, composed of stamped steel, is designed to circulate grass clippings for mulching.
Technical Specifications
  • Model Number: 917.388381
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 6.0 horsepower 4-cycle engine, model number 12H802-2675-E1
  • Cutting Width: 21 inches
  • Cutting Height: Adjustable between 1-3.75 inches, with 9 different height positions
  • Blade: 21 inch steel blade
  • Grass Catcher Capacity: 2.3 bushels
  • Mulching Capable: Yes
  • Side Discharge Capable: Yes
  • Wheel Size: 7 inch front wheels, 8 inch rear wheels
  • Weight: 60 lbs
  • Fuel Type: Regular unleaded gasoline
  • Fuel Capacity: 1.6 quarts
  • Engine Oil Capacity: 20 oz
  • Starter Type: Recoil starter
  • Ignition Type: Solid state ignition
  • Carburetor Type: Primer carburetor
Warranty
The Craftsman 21" Walk Behind Mower Model 917.388381 comes with a 2-year limited warranty. This warranty is designed to cover any defects in materials or workmanship that become apparent during the normal residential use of the product, given that the product has been maintained properly. The coverage includes both parts and labor and does not impose any limits on the number of hours used. To claim the warranty, it is usually required to contact the manufacturer or the retailer, providing proof of purchase and details about the defect. Specific procedures may vary, so it's recommended to refer to the warranty section in the product's owner's manual or the manufacturer's website.
Craftsman 917.388381 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 23
All Time: 303
