1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38819
Background
The Craftsman Walk Behind Mower 917.388190 is a self-propelled, gas-powered lawn mower. This model is manufactured by Roper Corp for Sears under the Craftsman brand. The product specifications include a Briggs & Stratton 10T802-1059-B1 159cc engine, a cutting width of 21 inches with an adjustable cutting height ranging from 1 to 3 inches, and wheels measuring 7 inches in the front and 8 inches at the rear. It has a blade speed of 3600 rpm, a gas tank capacity of 1 quart, and an oil capacity of 20 ounces. The mower weighs 66 pounds.
In terms of operation, the mower's engine speed is not adjustable and it is designed to mulch, bag, or side discharge grass clippings. The cutting height can be adjusted using the wheel height adjusters. The Craftsman Walk Behind Mower 917.388190 is suitable for residential lawn care, with key features including a 21-inch cutting width, side discharge/mulching/bagging options, and height adjustment. Regular maintenance, such as checking and changing oil, cleaning the air filter, replacing the blade, and lubricating parts, is recommended for optimal performance.
Technical Specifications
  • Model Number: 917.388190
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 10T802-1059-B1 159cc
  • Cutting Width: 21 inches
  • Cutting Height: 1-3 inches (adjustable)
  • Blade Speed: 3600 rpm
  • Wheels: 7 inch front, 8 inch rear
  • Gas Tank Capacity: 1 quart
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Weight: 66 pounds
Warranty
The Craftsman Walk Behind Mower 917.388190 comes with a 2-year full warranty that covers any manufacturer defects in material or workmanship. Should the mower exhibit any of these issues, the warranty covers repair or even replacement if the repair is deemed impossible. However, the warranty does not extend to expendable parts such as blades, belts, air filters, or any problems that may arise from improper maintenance or use. For commercial or rental use, the warranty coverage is shortened to 90 days.
Craftsman 917.388190 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 479
