1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388122
Background
The Craftsman Walk Behind Mower, model 917.388122, is a gas-powered lawn mower designed for residential use. It is equipped with a 3.5 horsepower Briggs & Stratton 124T02 engine and a 21-inch steel cutting deck. The cutting height can be adjusted between 1 to 4 inches, offering seven different positions controlled by a single lever. The machine uses a mulching blade, which cuts the grass into small pieces that decompose back into the lawn providing nutrients.
The mower has 6-inch front wheels and 8-inch rear wheels, along with a foldable T-shaped handle that offers two height positions. It also includes a 2-bushel grass collection bag. This mower weighs around 60 lbs and has a fuel tank capacity of 1.6 quarts. It operates on regular unleaded gasoline and uses either SAE 30 or SAE 5W-30 oil.
Technical Specifications
  • Model Number: 917.388122
  • Manufacturer: Sears
  • Product Type: Walk-behind rotary mower
  • Engine: Briggs & Stratton 124T02
  • Power: 3.5 hp
  • Cutting Width: 21 in
  • Cutting Height: 1-4 in (7 positions)
  • Fuel Type: Gasoline
  • Fuel Capacity: 1.6 quarts
  • Oil Type: SAE 30 or SAE 5W-30
  • Oil Capacity: 20 oz
  • Transmission: Manual push
  • Weight: Approximately 60 lbs
  • Wheel Size: 6 inch front wheels and 8 inch rear wheels
  • Handle: Foldable T-shaped with 2 height positions
  • Grass Collection Bag: 2-bushel mesh
  • Additional Features: Single lever height adjustment, mulching blade, convertible for rear bagging or side discharge.
Warranty
The Craftsman Walk Behind Mower model 917.388122 comes with a full warranty for a period of 2 years. This warranty covers any defects in materials or workmanship that may arise during this period. However, for commercial or rental use, the warranty is limited to only 90 days. It's important to note that consumable parts such as blades, belts, air filters, and spark plugs are not covered under this warranty. To claim the warranty, you should contact the manufacturer, Sears, directly.
Craftsman 917.388122 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 27
All Time: 300
