4 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388115
Background
The Craftsman Walk Behind Mower 917.388115 is a self-propelled, gas-powered lawn mower. Manufactured by Roper Corp for Sears, it is equipped with a Briggs & Stratton 122T02 21" Multi-Cut engine with a displacement of 163cc. The fuel capacity for this product is 1.6 quarts of unleaded regular gasoline. The oil type used varies depending on temperature conditions: SAE 30 above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 ounces. The recommended spark plug for this model is the Champion RJ19HX with a gap of .030". The blade bolt torque measures between 35-40 ft-lbs.
The mower features a 21" steel deck and a variable speed front wheel drive system, capable of reaching speeds up to 3.5 mph. Users can adjust the cutting height between 1-3/4" to 4" using its 9-position height adjustment lever. Its design allows for three different methods of handling grass clippings: mulching, bagging, or side discharge. The engine is initiated via a recoil starter, and it utilizes a primer carburetor for easier cold starts.
Technical Specifications
  • Model Number: 917.388115
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 122T02 21" Multi-Cut
  • Displacement: 163cc
  • Fuel Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Type: SAE 30 above 32°F; SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Spark Plug: Champion RJ19HX (gap: .030")
  • Blade Bolt Torque: 35-40 ft-lbs
  • Cutting Deck: 21" steel
  • Drive System: Variable speed front wheel drive system (up to 3.5 mph)
  • Cutting Height: Adjustable from 1-3/4" to 4" via a 9-position height adjustment lever
  • Clippings Disposal: Deck can mulch, bag or side discharge grass clippings
Warranty
The Craftsman Walk Behind Mower 917.388115 comes with a 2-year full warranty. This warranty covers any manufacturer defects in material or workmanship. If any such defects are found, the warranty provides for the repair or replacement of the product, if repair is not feasible. To claim the warranty, it's usually necessary to provide proof of purchase and notify the manufacturer of the defect. However, the exact process may differ, so it's recommended to consult the warranty terms or the manufacturer's customer service for specific instructions.
Craftsman 917.388115 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 22
All Time: 351
