No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.388061
Background
The Craftsman Walk Behind Mower 917.388061 is a lawn maintenance tool designed for mowing grass. This model is a rear discharge push lawn mower that is equipped with an engine from Briggs & Stratton, a well-known engine manufacturer. The engine is a 6.0 horsepower, 4-cycle variant that is powered by unleaded gasoline.
The mower has a cutting width of 21 inches and allows for adjustable cutting heights, ranging from 1 to 3.5 inches. There are 9 different height positions available, allowing the user to customize the height of the grass after mowing. The mower can hold up to 1.6 quarts of fuel and 20 ounces of oil. It's designed to discharge clippings from the rear but can also be converted to perform mulching or bagging operations. This model weighs a certain amount and has specific dimensions, though these are not specified in the provided context.
Technical Specifications
  • Model Number: 917.388061
  • Product: Craftsman Walk Behind Mower 917.388061
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 6.0 HP 4-cycle
  • Cutting Width: 21 inches
  • Cutting Height: 1-3.5 inches (9 positions)
  • Fuel Tank Capacity: 1.6 quarts unleaded gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 ounces
  • Blade Bolt Torque: 35-40 ft-lbs
  • Weight: xx lbs
  • Dimensions: yy in x zz in x aa in
Warranty
The Craftsman Walk Behind Mower 917.388061 comes with a limited two-year warranty. This warranty covers any defects in materials and workmanship, provided the mower is maintained according to the instructions in the operator's manual. However, if the mower is used for commercial purposes, the warranty coverage is reduced to 90 days from the date of purchase. Please note that the warranty does not extend to expendable parts such as blades, belts, and air filters. Also, issues resulting from improper use or lack of maintenance are not covered by this warranty.
Craftsman 917.388061 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 20
All Time: 301
