No Image
This wiki is missing a device image. Help improve this page by uploading one!
5 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38804
Background
The Craftsman Walk Behind Mower 917.388040 is a lawn mower designed for residential use. Manufactured by the Roper Corporation for Sears, this machine operates on a 4.5 horsepower Craftsman 143.034504 4-cycle engine. It utilizes 1.5 quarts of regular unleaded gasoline as fuel, and its oil capacity is 20 oz, with SAE 30 above 32°F and SAE 5W-30 below 32°F recommended. The machine also features a spark plug, specifically a Champion RJ19LM or J19LM with a gap of .030". Furthermore, the engine operates at a high speed of 2900 to 3200 rpm.
This mower is equipped with a 21-inch rear discharge mower deck. For cutting grass, this machine offers a 7-position height adjustment feature, ranging from 1-1/2 to 4 inches. It also has 2-point height adjustment for more precise control. Additionally, this machine has mulching and rear bagging capabilities. For convenient storage, the mower is designed with a folding T-shaped handle.
Technical Specifications
  • Model Number: 917.388040
  • Product Type: Walk Behind Mower
  • Engine: 4.5 horsepower, 4-cycle
  • Fuel Capacity: 1.5 quarts of unleaded regular gasoline
  • Oil Capacity: 20 oz SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Spark Plug Type: Champion RJ19LM or J19LM, gap .030"
  • Blade Bolt Torque: 35-40 ft lbs
  • Speed: High - 2900 to 3200 rpm
  • Discharge: 21 inch rear discharge mower deck
  • Height Adjustment: 7-position, from 1-1/2 to 4 inches
  • Handle: Folding T-shaped, 2-point height adjustment
Warranty
The Craftsman Walk Behind Mower 917.388040 comes with a 2-year limited warranty. This warranty covers defects resulting from the product's materials and workmanship. However, it does not include coverage for items that are subject to normal wear and tear. If the mower is used in a commercial setting or improperly maintained, the warranty becomes void. To claim the warranty, you would typically need to provide proof of purchase and contact the manufacturer or the retailer where you purchased the mower. It's important to keep in mind that terms and conditions may vary, so it's recommended to check the product's warranty card or consult the operator's manual for the most accurate information.
Craftsman 917.388040 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 63
All Time: 1,341
