No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Documents
Models
917.38761
Background
The Craftsman Walk Behind Mower 917.387610 is a lawn mower designed for cutting grass on residential lawns. Manufactured by the Roper Corporation for Sears, the mower is equipped with a 22-inch side discharge rotary blade that aids in maintaining a neat and uniform lawn. Its engine, a Craftsman 143.024200, is a 4.25 HP 4-cycle variant, capable of operating on 1.5 quarts of unleaded regular gasoline.
The mower also includes a manual start with a recoil starter, a feature that allows for easy operation. The 7-position height adjustment offers a range between 1-1/2" to 4", providing flexibility for different lawn requirements. An additional feature is the operator presence control bar which aids in controlling the operation of the mower. Regular maintenance, such as checking the engine oil, inspecting and cleaning the muffler and spark arrestor, cleaning the deck and underside, and servicing the air filter, helps to ensure the long-term operation and reliability of the mower.
Technical Specifications
  • Model Number: 917.387610
  • Product Type: Walk Behind Mower
  • Engine: 4.25 HP 4-cycle engine
  • Fuel capacity: 1.5 quarts unleaded regular gasoline
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 oz
  • Spark plug: Champion RJ19LM or J19LM, gap .030"
  • Blade bolt torque: 35-40 ft lbs
  • Deck: 22" steel
  • Mowing method: Side discharge
  • Height adjustment: 7-position, from 1-1/2" to 4"
  • Operator presence control: Control bar
  • Start method: Manual start with recoil starter
Warranty
The Craftsman Walk Behind Mower 917.387610 comes with a limited two-year warranty. This warranty covers any defects in materials and workmanship, provided the mower has been maintained as per the instructions in the operator's manual. Both parts and labor are included in this warranty for two years from the date of purchase if the mower is used for personal household use. Note that if the product is used commercially, the warranty coverage is reduced to 90 days from the date of purchase. The warranty does not extend to normal wear parts such as belts, blades, and air filters, nor does it cover issues arising from improper use, lack of maintenance, or damage. To claim the warranty, refer to the guidelines stipulated in the operator's manual and ensure all terms and conditions are met.
Craftsman 917.387610 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 475
