No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38749
Background
The Craftsman Walk Behind Mower 917.387490 is a gas-powered lawn mower. The mower is equipped with a Briggs & Stratton 125K02-0303-E1 4-cycle engine that delivers 6.75 ft-lbs of gross torque power. The mower has a cutting width of 22 inches and an adjustable cutting height, ranging from 1-3/4 inches to 4 inches, facilitated by 9-position height adjusters. The mower is a push type, with variable speed control and a 22-inch steel blade. The mower also includes an operator presence control bar and a discharge guard.
The fuel tank of the mower has a capacity of 1.6 quarts and runs on unleaded regular gasoline. It has an oil capacity of 20 oz with SAE 10W30 API SG-SL oil type. The mower uses a Champion RJ19HX spark plug with a gap of 0.030 inches and the blade bolt torque is set between 35-40 ft-lbs. It can be started by pushing the primer button 3 times, holding down the operator presence control bar, and pulling the starter cord quickly. The engine speed is preset and not adjustable. The mower housing can be converted for side discharge or bagging by removing the mulcher plug. Regular maintenance practices include checking and changing engine oil, cleaning or replacing the air filter, replacing the spark plug, inspecting and sharpening or replacing the blade, and cleaning under the mower deck.
Technical Specifications
  • Model Number: 917.387490
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 125K02-0303-E1 4-cycle, 6.75 ft-lbs gross torque power
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable from 1-3/4 inches to 4 inches, 9 positions
  • Drive: Push type, variable speed control
  • Blade: 22 inch steel blade
  • Fuel Tank Capacity: 1.6 quarts unleaded regular gasoline
  • Oil Capacity: 20 oz SAE 10W30 API SG-SL oil
  • Oil Type: SAE 10W30, API service classification SG-SL
  • Spark Plug: Champion RJ19HX (gap: 0.030 inches)
  • Blade Bolt Torque: 35-40 ft-lbs
Warranty
The Craftsman Walk Behind Mower 917.387490 comes with a limited warranty of 2 years provided by Sears. This warranty covers any defects in materials and workmanship of the product. To claim the warranty, one should contact Sears through their customer service channels, providing details about the defect and proof of purchase. It's important to note that warranty coverage may vary based on the nature of the defect and its cause, so keeping up with regular maintenance as outlined in the owner's manual can be beneficial.
Craftsman 917.387490 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 29
All Time: 700
