No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.387441
Background
The Craftsman Walk Behind Mower 917.387441 is a lawn mower designed for domestic use. Produced by Sears, Roebuck and Co., this 22-inch side discharge rotary lawn mower is powered by a Craftsman 6.5 HP 4-cycle engine. The engine has a displacement of 143 cc and runs on unleaded regular gasoline with a fuel capacity of 1.5 quarts. The mower also uses SAE 30 oil above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 oz.
The mower has a cutting width of 22 inches and a cutting height that adjusts between 1 to 3.5 inches, with nine position adjustment features. It operates using a manual push transmission and a recoil starter. Other features include an operator presence control bar and a folding steel handle for storage. The mower is suitable for operations that require side discharge of clippings only. It weighs 74 lbs. Routine maintenance such as cleaning to avoid buildup of grass and debris, and regular changing of oil and filter is recommended.
Technical Specifications
  • Engine: 6.5 HP 4-cycle engine
  • Displacement: 143 cc
  • Fuel Type: Unleaded regular gasoline
  • Fuel Capacity: 1.5 quart
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable, 1-3.5 inches, 9 positions
  • Start Method: Manual recoil
  • Transmission: Manual push
  • Product Weight: 74 lbs
Warranty
The Craftsman Walk Behind Mower 917.387441 comes with a 2-year limited warranty. This warranty typically covers defects in materials or workmanship, but each case is unique and will be evaluated individually by the manufacturer. To claim the warranty, the owner should refer to the instructions provided in the owner's manual or contact Sears, Roebuck and Co. directly. It is recommended to keep the purchase receipt as proof of the date of purchase, which is often needed when making a warranty claim.
Craftsman 917.387441 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 31
All Time: 270
