No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38714
Background
The Craftsman Walk Behind Mower 917.387140 is a gas-powered lawn mower with a 5 horsepower Craftsman 4-cycle engine. It is equipped with a 20-inch steel cutting deck. Other specifications of this mower include an 11.5 cubic inch engine displacement, a fuel tank capacity of 1.5 quarts, and a 20 oz oil capacity. The mower uses regular unleaded gasoline, with a minimum octane rating of 87, and its oil type varies with temperature conditions, using SAE 30 above 32°F and SAE 5W-30 below 32°F. The mower also has 7-inch front wheels, 8-inch rear wheels, and weighs about 70 lbs.
The mower is designed for residential lawn mowing and is not recommended for commercial use. Its cutting height can be adjusted from 1 to 3.5 inches depending on the desired grass length. It gives the user the option to mulch clippings, discharge them from the side, or collect them in an optional rear grass catcher bag. The mower's maintenance involves regular checks and replacements of engine oil, air filter, spark plug, and mower blade, along with cleaning and lubrication of certain parts. Craftsman lawn mowers, including this model, have been sold by Sears, Roebuck and Co. for over 50 years. The model 917.387140 was produced from 2010 to 2015 in the United States.
Technical Specifications
  • Model Number: 917.387140
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears
  • Engine: 5 horsepower, 4-cycle
  • Displacement: 11.5 cubic inch
  • Fuel Tank Capacity: 1.5 quarts
  • Fuel Type: Regular unleaded gasoline, minimum 87 octane
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade: 20 inches, steel deck
  • Cutting Height: Adjustable, 1 to 3.5 inches
  • Wheels: 7 inches front, 8 inches rear
  • Weight: 70 lbs
  • Additional Features: Operator presence control bar, Folding metal handles, Side discharge, mulching or rear bagging capability, Variable speed self-propulsion, Aluminum deck, Easy start pull recoil starter
  • Usage: Residential lawn mowing, not for commercial use
  • Manufacturing Years: 2010 to 2015
Warranty
The Craftsman Walk Behind Mower 917.387140 comes with a 2-year limited warranty both on the mower and its engine. This warranty covers any defects in the materials and workmanship of the product. In order to claim the warranty, service can be obtained from any Sears store. It is important to note that this warranty is limited, implying that it may not cover all types of damage or issues arising from the use of the mower. Therefore, it's advisable to check the specific terms and conditions of the warranty for detailed coverage information.
Craftsman 917.387140 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 20
All Time: 380
