2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38534
Background
The Craftsman Walk Behind Mower 917.385340 is a lawn mower that operates on gas. It's a product of Sears, a renowned manufacturer. The mower is equipped with a Briggs & Stratton 10M902-0489-E2 engine of 4.75 horsepower and a recoil start system. The mower's cutting width is 22 inches, and it provides adjustable cutting heights between 1 to 3.5 inches with nine different positions. The mower is self-propelled with the power directed to the rear wheels. It also features a 22-inch steel blade and a stamped steel deck.
The Craftsman 917.385340 is designed for residential lawn care. It features a broad cutting width that allows it to cover extensive areas. The self-propelled rear wheel drive provides power-assisted motion, reducing the effort required to push the mower. The cutting height can be adjusted across nine different positions, accommodating various grass lengths. An operator presence control bar is incorporated into the design, where the mower blade ceases to spin when the control bar is released. The mower operates with a Briggs & Stratton 10M902-0489-E2 gasoline engine and requires regular unleaded gasoline and SAE 30 motor oil. The mower's steel deck possesses rust-resistant properties.
Technical Specifications
  • Model Number: 917.385340
  • Product Type: Walk Behind Mower
  • Engine: 4.75 horsepower Briggs & Stratton 10M902-0489-E2 with recoil start
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable from 1 to 3.5 inches, with 9 position height adjustment
  • Drive Type: Self-propelled rear wheel drive
  • Blade: 22 inch steel blade
  • Deck Material: Steel
  • Control Type: Operator presence control bar
  • Fuel Type: Regular unleaded gasoline
  • Oil Type: SAE 30 motor oil
  • Assembly Required: Yes
Warranty
The Craftsman Walk Behind Mower 917.385340 comes with a 2-year limited warranty. This warranty covers any defects in the mower for two years under normal residential use, provided the owner is the original purchaser. It's important to note that the warranty does not extend to consumable parts. To claim the warranty, the owner must provide proof of purchase and the product must exhibit the defect during the warranty period. In most cases, the manufacturer will repair or replace the product free of charge.
Craftsman 917.385340 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 12
Past 30 Days: 27
All Time: 569
