2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.38512
Background
The Craftsman Walk Behind Mower 917.385120 is a manual push mower with a 22-inch width discharge. Produced by Sears, this machine is fitted with a Briggs & Stratton 4-cycle engine (10T802-0708-E1), characterized by a displacement of 163 cc and delivering 5.5 ft-lbs of gross torque. It runs on regular unleaded gasoline and uses SAE 30 oil or SAE 5W-30 when the temperature falls below 32°F. This mower has a cutting width of 22 inches, and its cutting height can be adjusted from 1-1/2 inches to 4 inches in six different positions. The deck is made of steel, and a 22-inch steel blade is used to cut the grass. The mower has a weight of 60 lbs and is equipped with 7 x 1-3/4 inch front wheels and 8 x 1-3/4 inch rear wheels.
The Craftsman Walk Behind Mower 917.385120 is designed with an operator presence control bar and a side discharge. It also offers a nine-position height adjustment feature and comes with a folding handle that aids in convenient storage. To start the engine, users must manually pull a rope recoil starter. The steel cutting deck enables the mower to cut a path 22 inches wide in a single pass. The height of the cut can be adjusted to suit individual requirements, and grass clippings are discharged from the right side during operation. Maintenance routines include checking the engine oil levels before each use, replacing or sharpening the blade, lubricating moving parts, and changing the engine oil, air filter, spark plug, and fuel filter as scheduled. The mower is powered by a battery that needs to be charged before winter storage.
Technical Specifications
  • Model Number: 917.385120
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 4-cycle, 10T802-0708-E1
  • Displacement: 163 cc
  • Power: 5.5 ft-lbs Gross Torque
  • Fuel Capacity: 1.0 quarts unleaded regular gasoline
  • Oil Capacity: 20 ounces SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable between 1-1/2 inches to 4 inches in 6 positions
  • Deck Material: Steel
  • Blade: 22 inch steel blade
  • Front Wheel Size: 7 x 1-3/4 inch
  • Rear Wheel Size: 8 x 1-3/4 inch
  • Weight: 60 lbs
Warranty
The Craftsman Walk Behind Mower 917.385120 comes with a comprehensive 2-year full warranty, which starts from the date of purchase. This warranty covers any defects in the materials and workmanship. It is important to note that if the mower is used commercially, the warranty period is limited to 90 days from the date of purchase. The warranty coverage includes both parts and labor for any repairs that are covered. To claim this warranty, it is usually required to provide proof of purchase, so keeping any receipts or documentation is advised.
Craftsman 917.385120 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 14
Past 30 Days: 30
All Time: 281
