3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.385123
Background
The Craftsman Walk Behind Mower 917.385123 is a lawn mower fueled by gasoline, produced by Sears, Roebuck and Co. This mower is equipped with a 22-inch side discharge mow deck and powered by a 10 hp Briggs & Stratton engine (model 10T802-3708-EA).
The specifications of the Craftsman 917.385123 include a 10 hp Briggs & Stratton 4-cycle engine with a displacement of 190 cc. It has a fuel capacity of 1.0 quarts and uses unleaded regular gasoline with a minimum of 87 octane. The mower utilizes SAE 30 oil above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 oz. The mower features a 22-inch steel mowing blade, with a cutting width of 22 inches and an adjustable cutting height ranging from 1 to 3.5 inches across seven positions. The mower is also capable of mulching and side discharge. The mower is designed with 7-inch front wheels and 10-inch traction rear wheels.
Additional features of the mower include an operator presence control bar which stops the engine when released, a folding T-shaped handle, an electric starter (battery not included), and a zone start throttle control. The mower can be maintained by changing the oil every 25 hours or seasonally, cleaning the air filter every 25 hours and replacing it every 100 hours or seasonally, and replacing the spark plug at the start of each mowing season or every 100 hours.
Technical Specifications
  • Model Number: 917.385123
  • Product Type: Walk Behind Mower
  • Engine: 10 hp Briggs & Stratton 4-cycle engine, model 10T802-3708-EA
  • Displacement: 190 cc
  • Fuel Capacity: 1.0 quarts unleaded regular gasoline (87 octane minimum)
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Blade: 22" steel mowing blade
  • Cutting Width: 22 inches
  • Cutting Height: 1-3.5 inches (7 positions)
  • Mulching Capability: Yes
  • Discharge: Side
  • Wheels: 7 inch front wheels, 10 inch traction rear wheels
  • Handle: Folding T-shaped
  • Starter: Electric starter (battery not included)
  • Throttle Control: Zone start
  • Discharge Capability: Mulching and side discharge
Warranty
The Craftsman Walk Behind Mower 917.385123 comes with a warranty that provides coverage for a period of 2 years if the product is used for residential purposes. However, if the mower is used commercially, the warranty period is reduced to 90 days. The warranty covers the full product, ensuring that the mower is free from any manufacturing defects and malfunctions when used as intended. To claim the warranty, you would typically need to provide proof of purchase and contact the manufacturer, Sears, Roebuck and Co., or the retailer where the mower was bought. It's important to note that any improper use or unauthorized modifications of the product may void the warranty.
Craftsman 917.385123 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 27
All Time: 305
