2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.384513
Background
The Craftsman Walk Behind Mower 917.384513 is a lawn mower that is powered by gas and produced by Sears. Its engine is a 149cc Kohler XT149 4-stroke OHV engine with a torque of 3.2 ft-lbs, and it is compliant with the 2006 CARB emission regulations.
The cutting system of this mower consists of a 21" multi-cut steel deck, with the blade's torque ranging between 35-40 ft-lbs. The height of the blade can be adjusted to 9 different positions, from 1-1/2" to 4". The mower has a variable speed front wheel drive and dual lever height adjusters. It also includes an operator presence control bar and a folding handle for storage. The mower has the ability to mulch, rear bag, and side discharge. Maintenance includes oil changes with a capacity of 20 oz and air filter and spark plug replacements every 100 hours or season.
Technical Specifications
  • Model Number: 917.384513
  • Product Type: Walk Behind Mower
  • Engine: 149cc Kohler XT149 4-stroke OHV
  • Gross Torque: 3.2 ft-lbs
  • Cutting System: 21" multi-cut steel deck
  • Blade Torque: 35-40 ft-lbs
  • Height Adjustment: 9 position from 1-1/2" to 4"
  • Operation: Variable speed front wheel drive
  • Height Adjusters: Dual lever
  • Control Bar: Operator presence control
  • Handle: Folding for storage
  • Options: Mulch, rear bag and side discharge
  • Oil Capacity: 20 oz
  • Oil Type: SAE 30 above 32°F, SAE 10W-30 below 32°F
  • Air Filter Replacement: Recommended every 100 hours or season
  • Spark Plug Replacement: Recommended every 100 hours or season
Warranty
The Craftsman Walk Behind Mower 917.384513 comes with a limited lifetime warranty on the mower deck, which means the deck is covered for as long as you own the mower. In addition, there is a five-year limited warranty on the engine. The limited warranty typically covers defects in the material or workmanship. Furthermore, a 90-day satisfaction guarantee is offered, which means if the product does not meet your satisfaction, you may be able to return it or exchange it within 90 days of purchase. To claim the warranty, you generally need to contact the manufacturer or the place of purchase, provide proof of purchase and describe the issue. Specifics might vary from one location to another, so it's best to check the warranty card or the manufacturer's website for the most accurate information.
Craftsman 917.384513 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 37
All Time: 351
