No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
917.38331
Background
The Craftsman Walk Behind Mower 917.38331 is a lawn maintenance tool produced by Roper Corporation for Sears' Craftsman line. This gas-powered, self-propelled mower was introduced in 2010 and is intended for residential lawn care and light mowing tasks.
The mower is equipped with a 163 cc Craftsman overhead valve engine with automatic choke and a pull start mechanism. It possesses a 21-inch steel mowing deck that discharges from the side and is capable of cutting a 20-inch path in a single pass. The cutting height can be adjusted between 1.25 inches and 3.75 inches with six different positions via a single lever. The mower has a fuel capacity of 0.9 gallons and weighs 160 lbs. It features rear-wheel drive with variable speed control. The mower also has a deck wash system for cleaning, which can be connected to a garden hose to remove debris.
Technical Specifications
  • Model Number: 917.38331
  • Product Type: Gas-Powered Walk Behind Mower
  • Production Year: 2010
  • Engine: 163 cc overhead valve engine with automatic choke and easy pull start
  • Mowing Deck: 21" steel with side discharge
  • Cutting Path Width: 20"
  • Cutting Height Positions: 6, adjustable from 1.25" to 3.75" using a single lever
  • Fuel Tank Capacity: 0.9 gallons
  • Weight: 160 lbs
  • Drive: Rear wheel drive with variable speed control
  • Steering: Power steering
  • Handle: Padded comfort grip
  • Wheels: 7" front wheels and 8" rear wheels
  • Deck Cleaning: Deck wash system for connecting a garden hose
  • Optional Attachment: Mulch kit
Warranty
The Craftsman Walk Behind Mower 917.38331 is provided with a 2-year limited warranty. This warranty covers defects in materials and workmanship for non-commercial use, ensuring the consumer protection against manufacturing faults. However, it should be noted that the warranty does not cover damage resulting from improper use, lack of maintenance, or normal wear and tear, emphasizing the importance of proper handling and regular upkeep of the mower for optimal performance. The engine warranty is handled separately by the manufacturer. To claim the warranty, proof of purchase is required, hence it is important for the buyer to keep the purchase receipt or any document that can verify the purchase.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 10
Past 7 Days: 12
Past 30 Days: 19
All Time: 211
