No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
917.38327
Background
The Craftsman Walk Behind Mower 917.38327 is a gas-operated lawn mower, produced by the Roper Corporation for Sears under the Craftsman brand. This mower is suitable for use in mid-sized yards up to half an acre. It is equipped with a 190cc Briggs & Stratton engine, which is started by means of a standard recoil mechanism. The mower has a steel deck that spans 21 inches and a handle that can be folded for compact storage.
The mower has a cutting height range of 1.5 to 4 inches, adjustable across 6 different settings. It features 7-inch front wheels and 8-inch rear wheels, dual point height adjusters, and a zone start switch which enables the mower to start with the bail engaged. Maintenance for this mower involves changing the engine oil after the initial 5 hours of operation, and subsequently every 50 hours or at the end of the mowing season. The air filter requires regular inspection and replacement when dirty. The underside of the mower deck should also be cleaned regularly to prevent the buildup of grass clippings and debris. The blade should be sharpened or replaced periodically to maintain its cutting performance.
Technical Specifications
  • Model Number: 917.38327
  • Product Type: Walk Behind Mower
  • Engine: 190cc OHV engine
  • Cutting Width: 21 inches
  • Cutting Height Range: 1.5 to 4 inches (6 settings)
  • Weight: 66 lbs
  • Fuel Tank Capacity: 0.9 gallons
  • Wheel Size: 7 inches front, 8 inches rear
  • Starting System: Standard recoil start
Warranty
The Craftsman Walk Behind Mower 917.38327 comes with a 2 year limited warranty. This warranty covers defects in materials and workmanship when the mower is used for non-commercial purposes. Please note that the warranty will become invalid if the mower is used commercially or if it is not maintained properly. Moreover, the engine warranty is handled separately by Briggs & Stratton. In addition to the product warranty, owners have the option to enroll in Craftsman's Overhaul Protection program. This program extends the warranty for the lifetime of the product and includes free tune-ups and repairs.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 22
All Time: 226
