No Image
This wiki is missing a device image. Help improve this page by uploading one!
1 Diagram
Ask a Question
There are no questions. Be the first to ask a question!
Models
917.380402
Background
The Craftsman Walk Behind Mower 917.380402 is a gas-powered lawn maintenance tool. It was produced by Sears Holdings Corporation under the Craftsman brand. This mower is self-propelled and features a 22" steel mowing deck. It operates using a 163cc Briggs & Stratton engine with automatic choke and ready start technology. The technology enables the mower to start with minimal effort.
The mower features a variable speed rear wheel drive that can achieve speeds of up to 3.5 mph. This allows the user to adjust the speed of mowing according to their preference. The mower also has seven cutting height positions that range from 1-1/2" to 4", providing flexibility in determining the cutting height. The height can be adjusted using dual lever height adjusters. The mower has an 8" front wheel and a 10" rear wheel. It also features an ergonomic loop style handle for comfortable control during mowing.
Technical Specifications
  • Model Number: 917.380402
  • Product Type: Walk Behind Mower
  • Engine: 163cc Briggs & Stratton
  • Deck Size: 22"
  • Cutting Widths: 22"
  • Cutting Heights: 1-1/2" to 4" (7 positions)
  • Drive System: Variable speed rear wheel drive
  • Speeds: Up to 3.5 mph
  • Front Wheels: 8"
  • Rear Wheels: 10"
  • Weight: 100 lbs
Warranty
The Craftsman Walk Behind Mower 917.380402 is equipped with a 2-year limited warranty. This warranty primarily covers any defects relating to materials or workmanship for a span of two years from the date of purchase. It is important to note that the warranty is specifically applicable to non-commercial use by the original purchaser. Certain exclusions are present, such as instances of normal wear and tear, improper maintenance, or abuse, which are not covered under the warranty. To avail of the warranty service, it is necessary to contact a Sears service center. One must also provide proof of purchase when claiming the warranty.
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 19
All Time: 240
