No Image
This wiki is missing a device image. Help improve this page by uploading one!
6 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37981
Background
The Craftsman Walk Behind Mower 917.379810 is a gardening tool designed for mowing lawns, produced by Roper Corp for Sears under the Craftsman Brand. This walk-behind mower is equipped with a 6.75 horsepower 4-cycle engine, and a cutting width of 21 inches, which can be adjusted between 1-3.5 inches in height across 6 different settings. Its versatility is showcased with its mulching, rear bagging, and side discharge capabilities. The mower runs on unleaded gasoline, with a fuel capacity of 1.5 quarts. The machine, weighing 55 lbs, is fitted with 7 x 2 inch front wheels and 9 x 2 inch rear wheels, providing adequate mobility for varying terrains.
To maintain the mower, users need to change the engine oil every 25 hours or at the end of each mowing season, clean the air filter, replace the spark plug annually, and sharpen or replace the blade as needed. The mower is designed to be user-friendly, with features such as a 3-position adjustable handle and a single point height adjuster to modify all four wheel heights. Additionally, it can be folded for convenient storage.
Technical Specifications
  • Engine: Craftsman 6.75 horsepower 4-cycle engine, model 143.016724
  • Cutting width: 21 inches
  • Cutting height: Adjustable between 1-3.5 inches in 6 steps
  • Capabilities: Mulching, rear bagging and side discharge
  • Front wheels: 7 x 2 inches
  • Rear wheels: 9 x 2 inches
  • Weight: 55 lbs
  • Fuel type: Unleaded gasoline
  • Fuel capacity: 1.5 quarts
  • Oil type: SAE 30 (above 32°F); SAE 5W-30 (below 32°F)
  • Oil capacity: 20 oz
  • Blade bolt torque: 35-40 ft-lbs
  • Handle: 3-position adjustable
  • Height adjuster: Single point for all four wheels
  • Start method: Recoil start
  • Carburetor: Fixed jet
  • Storage: Can be folded for compactness
Warranty
The Craftsman Walk Behind Mower 917.379810 comes with a 2 year limited warranty. The specifics of what this warranty covers are not detailed in the provided text, but typically, a limited warranty covers any defects in materials or workmanship. To claim the warranty, it is usually necessary to contact the manufacturer or retailer, in this case, Sears. The exact process might require providing proof of purchase or the model number of the product. Therefore, it is advisable to retain all purchase documents and note down the model number.
Craftsman 917.379810 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 11
Past 7 Days: 12
Past 30 Days: 21
All Time: 236
