No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Documents
Models
917.379202
Background
The Craftsman Walk Behind Mower 917.379202 is a self-propelled lawn mower, operating on gas, which was manufactured by Roper Corp for Sears. Its technical specifications include a 6.25 HP Briggs & Stratton engine, a 22-inch cutting width, and a cutting height that varies from 1 to 3.5 inches, adjustable in 9 positions. The mower also provides options for mulching or side discharge of grass clippings. The drive type is variable speed front wheel, with a weight of 92 lbs. The mower is equipped with 7-inch front wheels and 8-inch rear wheels.
The Craftsman 917.379202 was designed for use in medium-sized yards. The mower is equipped with a steel mowing deck and an auto-choke feature for easy starting. The variable speed front wheel drive can be controlled using a bar mounted on the upper handle. For convenience, the handle can be set in either a high or low position and can be folded for compact storage. The mower also comes with a control bar for operator presence and a zone start engine to prevent inadvertent starting.
Technical Specifications
  • Engine: 6.25 HP Briggs & Stratton, 123K02-0313-E1 model
  • Cutting Width: 22 inches
  • Cutting Height: Adjustable from 1 to 3.5 inches with 9 position setting
  • Mulching and Side Discharge: Yes
  • Drive Type: Self-propelled, variable speed, front wheel drive
  • Wheels: 7 inch front wheels, 8 inch rear wheels
  • Weight: 92 lbs
  • Presence Control Bar: Yes
  • Foldable Handle: Yes
  • Mulching Blades: Included
  • Start Method: Zone start engine
Warranty
The Craftsman Walk Behind Mower 917.379202 comes with a 2-year limited warranty. This warranty covers any defects in materials or workmanship but does not extend to normal wear parts such as belts, blades, and air filters. To claim the warranty, the mower should be returned to a Sears store or any other authorized service center.
Craftsman 917.379202 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 353
