No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.37898
Background
The Craftsman Walk Behind Mower 917.378980 is a gas-powered lawn mower. This product is manufactured by Roper Corporation for Sears under the Craftsman brand. It has a self-propelled feature and utilizes a 7 horsepower Briggs & Stratton engine. The mower's displacement is rated at 163 cc and it is designed to run on unleaded regular gasoline with a minimum of 87 octane. It has a fuel capacity of 1.6 quarts. The oil type recommended for the mower is SAE 30 above 32°F and SAE 5W-30 below 32°F, with an oil capacity of 20 ounces.
The mower has a cutting width of 22 inches and the cutting height can be adjusted between 1 and 3.5 inches across 9 positions. It has a weight of approximately 66 lbs. The mower is designed with a variable speed front wheel drive that is controlled through the operator presence control bar and the drive control bar. The mower deck is made of stamped steel and can accommodate both mulching and rear discharge modes. The handle of the mower can be folded in order to save storage space.
Technical Specifications
  • Model Number: 917.378980
  • Product Type: Walk Behind Mower
  • Engine: 7 hp Briggs & Stratton engine, model 128602-0304-E1
  • Displacement: 163 cc
  • Fuel type: Unleaded regular gasoline, 87 octane minimum
  • Fuel capacity: 1.6 quarts
  • Oil type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil capacity: 20 ounces
  • Cutting width: 22 inches
  • Cutting height: 1-3.5 inches (9 positions)
  • Weight: 66 lbs
Warranty
The Craftsman Walk Behind Mower 917.378980 comes with a 2-year limited warranty. This warranty is applicable for residential purposes and it covers any defects that arise due to faulty materials or workmanship. However, for commercial use, the warranty coverage is for only 90 days. It's important to note that the warranty does not cover normal wear items like blades, belts, air filters, etc. If you need to claim the warranty, refer to the instructions provided in the product's manual or contact the manufacturer directly. Be sure to retain your purchase receipt as it might be required for warranty claims.
Craftsman 917.378980 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 22
All Time: 435
