No Image
This wiki is missing a device image. Help improve this page by uploading one!
2 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.378761
Background
The Craftsman Walk Behind Mower 917.378761 is a gas-powered lawn mower produced by Roper Corporation for Sears. It is equipped with a 6.25 horsepower 4-cycle OHV gas engine from Briggs & Stratton, model number 123K02-0315-E1. This engine has a fuel capacity of 0.6 quarts and uses regular unleaded gasoline with a minimum 87 octane rating. The engine oil capacity is 20 ounces.
The mower incorporates a 21-inch steel cutting deck with a side discharge. The cutting height can be modified between 1 and 3.75 inches in 9 increments through a single lever height adjuster on each wheel. The mower uses a rear wheel drive system, which can be engaged by pushing the drive control lever forward. Variable forward speeds can be achieved based on how far the lever is pushed. An optional rear grass catcher bag can be utilized to gather clippings during mowing. The mower measures 43 inches in height, 61 inches in length, and 21 inches in width, and it weighs 80 pounds.
Technical Specifications
  • Model Number: 917.378761
  • Product Type: Walk Behind Mower
  • Manufacturer: Sears
  • Engine Type: 123K02-0315-E1 Briggs & Stratton 6.25 horsepower 4-cycle OHV gas engine
  • Fuel Capacity: 0.6 quart
  • Fuel Type: Regular unleaded gasoline with a minimum 87 octane rating
  • Engine Oil Capacity: 20 ounces
  • Cutting Deck Size: 21 inches steel cutting deck with a side discharge
  • Cutting Height: Adjustable from 1-3.75 inches in 9 increments
  • Drive System: Rear wheel drive with variable forward speeds
  • Grass Catcher: Optional rear grass catcher bag
  • Dimensions: Height - 43 inches, Length - 61 inches, Width - 21 inches
  • Weight: 80 pounds
Warranty
The Craftsman Walk Behind Mower model 917.378761 comes with a limited two year warranty, provided by Sears. This warranty protects against defects in materials and workmanship, as long as the mower is maintained according to its manual. However, please note that normal wear items such as belts, blades, and brake pads are not included in the warranty. If the mower is used for commercial or rental purposes, the warranty period is reduced to 90 days. To claim the warranty, you would need to reach out to Sears, providing them with details of the defect and proof of purchase.
Craftsman 917.378761 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 480
