No Image
This wiki is missing a device image. Help improve this page by uploading one!
3 Diagrams
Ask a Question
There are no questions. Be the first to ask a question!
Documents
Models
917.378492
Background
The Craftsman Walk Behind Mower 917.378492 is a gas-powered mower designed for lawn maintenance. This product was manufactured by the Roper Corporation for Sears under the Craftsman brand. It is equipped with a Briggs & Stratton 125K02-0253-E1 6.75 HP engine, providing the power necessary to maintain a variety of lawn sizes. The mower has a 21-inch cutting width and a variable speed rear-wheel drive system which allows the operator to adjust the speed to match their pace.
The Craftsman Walk Behind Mower 917.378492 offers seven adjustable height settings ranging from 1.5 to 4 inches, allowing for flexible and customized lawn cutting. It also includes rear bagging and mulching capabilities, offering the user options to manage the grass clippings. The mower is operated by an operator presence control bar which must be squeezed against the handle to start the engine. The self-propulsion system is engaged by holding the operator presence bar while pulling up the variable speed drive control bar. The Craftsman Walk Behind Mower 917.378492 requires maintenance such as oil level checks, oil changes, air filter replacements, and blade checks.
Technical Specifications
  • Model Number: 917.378492
  • Product Type: Walk Behind Mower
  • Engine: Briggs & Stratton 125K02 6.75 HP
  • Cutting Width: 21 inches
  • Drive System: Variable speed rear-wheel drive
  • Cutting Heights: Adjustable settings from 1-1/2 to 4 inches
  • Mulching/Bagging: Rear bagging and mulching capabilities
  • Fuel Tank Capacity: 1.6 quarts unleaded gasoline
  • Oil Type: SAE 30 above 32°F, SAE 5W-30 below 32°F
  • Oil Capacity: 20 oz
  • Spark Plug: Champion RJ19LM (gap: 0.030")
  • Blade Bolt Torque: 35-40 ft-lbs
  • Safety Features: Operator presence control bar
Warranty
The Craftsman Walk Behind Mower 917.378492 comes with a 2-year limited warranty. This warranty covers any defects in materials or workmanship for non-commercial use. Key components such as the engine, deck, and other components are covered under this warranty. However, normal wear items like blades, belts, air filters, and spark plugs are not included. For commercial or rental use, the warranty coverage is limited to 90 days.
Craftsman 917.378492 Owners Manual
iRobot
1 Reputation
632 Guides authored
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 28
All Time: 578
